How to identify different drives using HDD raw copy
Posted: March 5th, 2012, 9:18
by swifttom
Hi I would like to know how can one differentiate between 2 exact flash disk drives when using HDD raw copy. I am just terrified I make an image of the blank drive over the one with all the data on.
Re: How to identify different drives using HDD raw copy
Posted: March 5th, 2012, 10:43
by loki
If using windows try looking in disk management. Plug one flash drive in & it will tell you what it is ie disk1 etc then plug second one in & check again ie disk2
loki
Posted: March 7th, 2012, 22:58
by pad15
You can make an image of the first flash disk containg data
to a file onto your hard disk, then plug the blank one and write
from the image file.
