| Intel SSD Drive 80GB http://forum.hddguru.com/viewtopic.php?f=10&t=22849 |
Page 1 of 1 |
| Author: | HDDTECH [ May 5th, 2012, 12:16 ] |
| Post subject: | Intel SSD Drive 80GB |
Hello everybody: I have a Intel SSDSA2MH080G1C, (2.5" SSD X25 sseries)? When power on it stay BSY . So i open the case to unsolder chips, but the solderside covered with a black hard resin. Is anybody have a good Idea 1. why it stay busy , or how to remove chips in this case . Thanks for answer |
| Author: | loki [ May 5th, 2012, 12:39 ] |
| Post subject: | Re: Intel SSD Drive 80GB |
http://www.google.co.uk/search?tbm=vid& ... resin&sa=N If your planning on removing the chips to read the data then you need specialist kit like pc3000 ssd flash or soft centre kit & only then if its supported. Loki |
| Author: | HDDTECH [ May 7th, 2012, 9:44 ] |
Hi Loki: i got both of them. I need if any soloution to pull chip out or is there any fix on the circuit board to get it going. |
| Author: | Jar [ May 7th, 2012, 10:10 ] |
I think epoxy remover should take the black stuff off. Be careful though. Are they TSOP chips or BGA? Before pulling the chips of I would check the web to see if they are encrypted. IF they are encrypted, you won't be able to do much. Upload a pic of the board if you can. |
