Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: NEED A DONOR FLASH USB PCB SONY MICROVAULT 16GB
PostPosted: May 9th, 2012, 8:07
Hi everyone, i'm dealing with a recovery case but the nand chips on the flash are not supported or gives alot of bits errors by F.E or PC-3000 SSD version, the NANDS are:
SAMSUNG K9BCG08U1A x2 and the microcontroller is a Silicon Motion SM3255Q-AB the NANDS are TLGA-52 if someone has this board working please PM ME.
i bought a couple of new ones but they have different nands and microcontrollers.
Regards.
Rafael.
 Post subject: Re: NEED A DONOR FLASH USB PCB SONY MICROVAULT 16GB
PostPosted: May 9th, 2012, 8:24
NAND chip K9BCG08U1A operates not at 3.3V, which NAND reader will read it at. I believe it reads at 1.8/1.9V which is why you get many errors.
What is wrong with original PCB, do you have opportunity to repair it? Post a photo of it here
PostPosted: May 9th, 2012, 8:32
Impossible to repair, i have the proper equipment but no use, the board is broken in two pieces and there's more than 2 layers, could take me entire weeks to analyze the board and fix it.
PostPosted: May 10th, 2012, 0:19
agree. and have other way for improve reading result. but still no prefect. :(
@Izualim
i offten meet such case. my cases are PCB is good. had to read chip for data recovery. let me check it have in lab or no.
data recovery service[/b]
PostPosted: May 10th, 2012, 2:56
Thanks, i'll really appreciated. :)
PostPosted: May 10th, 2012, 3:33
I don't have a datasheet, but Samsung's catalogue identifies the K9BCG08U1A as a 64Gbit 3.3V MLC Flash.
The "U" in the part number denotes a Vcc range of 2.7V~3.6V.
http://www.datasheetarchive.com/indexdl ... 344599.pdf
PostPosted: May 10th, 2012, 4:07
indeed you are right, voltage are between the range of the readers.
PostPosted: May 10th, 2012, 8:23
hi,
sorry. don't have LGA52 PCB. but i have special TSOP48 PCB with this controller.
PostPosted: May 10th, 2012, 10:08
Thanks sunny but must be have the same pin connections, Thanks For Checking your stock! :)
PostPosted: May 10th, 2012, 23:44
welcome.you can use it for your LGA chip if you know well with it. as know Transcend 8G or 4G pen drive will have same thing as your.
PostPosted: May 11th, 2012, 9:47
the pcb must be for 2 nands so the mixing between them match, also with the same capacity, the controller might work differently depending on the capacities of the flashes.
PostPosted: May 13th, 2012, 0:24
two case with this controller come. one is TSOP48,one is two LGA52. PCB is good. let me finish it first and i will talk to customer. :wink:
PostPosted: May 14th, 2012, 3:02
Nice, let me know if the client agreed and if you could upload some photos of the board :)
PostPosted: May 14th, 2012, 19:55
hi,
LGA52 case success 98% recovery. but i still no talk with customer that i want keep this board. you need photo only? please contact me by IM. i can send photo to you immediately if need photo only.
PostPosted: May 15th, 2012, 4:11
added to skype.
PostPosted: May 22nd, 2012, 4:19
I'd take a photo of the damaged pcb and if you see one of the nands is also damaged, but i was able to read it, and gave me around the same bit errors that the another, i might still be lucky if i found the correct pcb.
PostPosted: May 22nd, 2012, 8:10
second chip is broken. please show me high quality images of broken one both side. please double check it to see it possible to recovery or not. had to think about it. BTW. i every week have some SM3255Q come here. you can try with TSOP48. sorry about last BGA one. customer had to take it back.
PostPosted: May 22nd, 2012, 8:24
I was able to read all the banks from the broken nand, none of the pins has been broken and as i said before i got around the same bit errors like the other, i need a board to test, let me know if you find the proper board.
PostPosted: May 23rd, 2012, 19:14
will keep looking for you :)
PostPosted: May 24th, 2012, 3:06
Appreciated.
