Page 1 of 1
sdhc card not recognized
Posted: June 28th, 2012, 5:19
by cat1x
Hi, I have a sdhc Lexar card not recognized by operative system. Card can't be formatted in windows/Linux or in an digital camera.
WinHex detects it as 2,0KB device but crashes if I try open it or clone it. Linux detects it as 2KB:
[ 302.776821] scsi 2:0:0:0: Direct-Access Single Flash Reader 1.00 PQ: 0 ANSI: 0
[ 302.786082] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 303.229039] sd 2:0:0:0: [sdb] 4 512-byte logical blocks: (2.04 kB/2.00 KiB)
[ 303.229771] sd 2:0:0:0: [sdb] Write Protect is on
[ 303.229779] sd 2:0:0:0: [sdb] Mode Sense: 03 00 80 00
Is not possible mount it or dd it.
As it's a monolithic card, I can't read chip with pc-3000 flash
Do you have experience with this kind of cards? Any suggestion?
Thanks in advance
Re: sdhc card not recognized
Posted: June 29th, 2012, 9:18
by pcimage
"As it's a monolithic card, I can't read chip with pc-3000 flash"
Do you have the Soft Center tool with the SD adaptor?
Sometimes you can access these monolithic cards using Image Explorer with the "Adaptor_SD.dll" plugin and make an image.
Not often I must admit, but in 20-30% of cases it works
Posted: June 29th, 2012, 11:40
by cat1x
Hi pcimage,
I don't have this tool neither the adapter. Have you tested if this adapter works correctly with sdhc cards?
The adapter is xD/SD but SD and SDHC cards are differents.
Posted: July 3rd, 2012, 15:41
by arvika
Show the photo of card. If it is monolith, special connection to card will be needed.
Posted: July 6th, 2012, 7:01
by cat1x
This is the card, photo isn't very good but I have only this one. What special connection is needed if pinout is unknown?
Posted: July 8th, 2012, 14:42
by arvika
I can't see anything on this photo. Show sharp photo and good resolution, something like that:
Posted: July 10th, 2012, 10:13
by cat1x
arvika, thanks for your help but I have already returned the card
Posted: August 13th, 2012, 7:22
by jeremyb
Posted: August 14th, 2012, 9:39
by hddguy
You have pin out for this? Did you recover such case before?
Posted: August 14th, 2012, 12:41
by einstein9
hddguy wrote:You have pin out for this? Did you recover such case before?
i got many cases like this, and 99% of them are dead-end with me here
since flashes DR is not really my priority concern here
good luck with this hddguy
Vlad. might help on this.
Posted: August 21st, 2012, 12:11
by hddguy
einstein9 wrote:i got many cases like this, and 99% of them are dead-end with me here
Thanks, but I dont need one recovered, I was wondering if pinout was available. I have many pinouts but not this specific one.
Posted: August 21st, 2012, 13:34
by einstein9
if am not mistaken here hddguy, i guess (not sure) once i asked Vlad. and he told me SOME people sell those pinouts - not sure
it may or may not.
