Sandisk - Cruzer Edge [ DR solution ]
http://forum.hddguru.com/viewtopic.php?f=10&t=23461
Author:  Amarbir[CDR-Labs] [ July 13th, 2012, 14:30 ]
Post subject:  Sandisk - Cruzer Edge [ DR solution ]
Hi Folks,
Got a Case of a Cruzer Edge 8Gb From Sandisk .First Issue Is Opening the Same Without Spoiling It . Does anyone Have a clue How to Crack Open the Monolith PCB From The Plastic ? .
Author:  pcimage [ July 13th, 2012, 14:53 ]
Post subject:  Re: Sandisk - Cruzer Edge [ DR solution ]
Sure it's monolith?
All the cruzer edges I had in have PCB with usual flash and controller setup.
Author:  Amarbir[CDR-Labs] [ July 13th, 2012, 15:07 ]
pcimage wrote:
Sure it's monolith?
Sean ,
I am Not sure Of The Same .Never Had a Case Of The Same .Can You Explain Me How To Crack Open The Same From The Plastic .It Seems Very Flimsy and i Do Not Want Any Messups
