 Post subject: Nexus S "wipe data/factory reset"
PostPosted: July 30th, 2012, 22:43
Today I have unlocked my Nexus S's bootloader. After unlocking, all data was wiped from the phone, however, I was not aware that the sdcard would be wiped along with the system data. Assuming my files were saved, I rebooted my phone to realize that, in fact, the sdcard had been formatted. I am here to ask if there is any chance of recovering the lost partition even though android system wrote files to the sdcard after format.
Thanks in advance.
 Post subject: Re: Nexus S "wipe data/factory reset"
PostPosted: July 31st, 2012, 9:03
Thanks in advance.
Depends on how it was formatted. If the sectors were overwritten then your out of luck.
Download & install winhex on a pc then attach the sdcard.
Start winhex & then open tools>open disk & select your sdcard
Then look at the sectors to see if they have been zero'd or if a pattern has been written.
You could also try rstuido data recovery software
PostPosted: August 1st, 2012, 5:12
This article explains what to do in your case: Photo Recovery. R-Undelete is based on the same data recovery engine as R-Studio, but easy in use.
R-Studio Data Recovery Software
PostPosted: August 1st, 2012, 11:31
Thank you for the responses. After looking at the device in WinHex, I discovered that 0s have been written over the data. I tried R-Undelete anyway, but as I expected, it did not retrieve any data. Thanks anyway.
Users browsing this forum: No registered users and 121 guests
