| PQI 8gb cant reformat http://forum.hddguru.com/viewtopic.php?f=10&t=23638 |
Page 1 of 1 |
| Author: | gripos [ August 3rd, 2012, 13:50 ] |
| Post subject: | PQI 8gb cant reformat |
i have this USB its 8gb and i cant format, it says write protect and i try to format the 8gb at Windows xp partition mode nothing happen.. while my other usb 2gb PQI U230 even got the same problem but sometimes i can reformat..i try other solution but all failed even i edit at regedit policy i just want to reformat the 8gb and use to back-up my files.... |
| Author: | loki [ August 3rd, 2012, 13:58 ] |
| Post subject: | Re: PQI 8gb cant reformat |
gripos wrote: i have this USB its 8gb and i cant format, it says write protect and i try to format the 8gb at Windows xp partition mode nothing happen.. while my other usb 2gb PQI U230 even got the same problem but sometimes i can reformat..i try other solution but all failed even i edit at regedit policy i just want to reformat the 8gb and use to back-up my files.... Courious that you say you've had the same problem with other usb pen drives on the same pc. Firstly id be looking more at the pc/os If it was just the one usb pen with issues then yes it could be faulty. Try using a different pc to format the usb pen if it works then you know the issue is your pc/os. |
| Author: | gripos [ August 3rd, 2012, 14:15 ] |
| Author: | northwind [ August 6th, 2012, 2:50 ] |
Is this a new 8GB USB bought from China for a very low price? |
| Author: | jeremyb [ August 13th, 2012, 7:18 ] |
For an 8GB flash drive, why waste your time and effort, just buy a new flash drive. I'm actually more surprised that it got to 1.1GB before failing. I "guess" you could always try partitioning around the bad area, but like I said 8GB flash drives are dirt cheap. |
