 Post subject: Damaged USB memory stick - "No media"
PostPosted: April 15th, 2013, 9:05
A collegue's daughter pulled out their USB memory stick when a file was still copying (in Windows 7)
Normally this would just result in some minor file system corruption (FAT32) and an inconsistent or damaged file
However in this case the USB memory stick became totally unusuable
Under windows the USB bridge part still shows up ok as a Removable drive
but it shows "No Media"
details of stick model etc to follow
I've not got my hands on it yet, but assume that low level reads on the drive will fail, hence nothing I can do at the logical level
Any thoughts on the viability and cost of recovery (UK based) ?
Thanks in advance
viewtopic.php?f=10&t=20230&p=135658&hilit=+no+media+#p135658
is a similar case
 Post subject: Re: Damaged USB memory stick - "No media"
PostPosted: April 15th, 2013, 9:22
Flash media has its own translation tables to account for bad block management, wear leveling and data distribution. I would guess that some aspect of this is damaged. Not sure if there would be some specific repair possible, but almost certainly the data can be recovered by someone with the right tool and knowledge for it.
It would be useful to know the controller it uses, can almost certainly tell you the recover-ability of it then
PostPosted: April 15th, 2013, 9:27
Thanks in advance
is a similar case
pcimage is one of the people i know, contact him
Users browsing this forum: Majestic-12 [Bot] and 94 guests
