 Post subject: How do you safely open up an SD card?
PostPosted: April 14th, 2013, 12:03
SD cards appear to be robust little devils to open.
I cannot find any good incision points.
What is your strategy for physically opening an SD card?
 Post subject: Re: How do you safely open up an SD card?
PostPosted: April 14th, 2013, 15:23
Sharp blade carefully around the seam....as soon as you have an opening then use your thumbnail to finish the job.... SIMPLES!!!!....
http://www.eadr.co.uk
PostPosted: April 15th, 2013, 4:37
Don't expect to be able to close it back up for use, not easily anyway ;)
PostPosted: April 25th, 2013, 18:19
i open it from connect pins side. as flash chip never be there. then following Touchclarity's way :)
data recovery service[/b]
Users browsing this forum: No registered users and 122 guests
