| iPhone is disabled connect to iTunes http://forum.hddguru.com/viewtopic.php?f=10&t=26161 |
Page 1 of 1 |
| Author: | jag17 [ June 5th, 2013, 21:54 ] |
| Post subject: | iPhone is disabled connect to iTunes |
I have an iPhone that says iPhone is disabled connect to iTunes I believe the phone was locked with passcode, and it was tried too many times with wrong passcode Below link for more information http://support.apple.com/kb/ht1212 The owner of the phone is no more and no one knows the passcode now. There is no backup to computer also. Anyone came accross and recovered data in this kind of scenario ? |
| Author: | craig6928 [ June 5th, 2013, 22:22 ] |
| Post subject: | Re: iPhone is disabled connect to iTunes |
apple security software will delete all the data and everything of the iphone if the person tries to put the wrong password in to many times which you phone now says iPhone is disabled so more likely data has been ERASURE only other option which you dont have is connect the iphone to itunes to restore which you dont have only way is to restore back to factory mode everything is gone once the iphone is connected to itunes it has a special id key this tells apple everything about the ownership of the phone and it does communicate direct with apple |
| Author: | poehere [ June 10th, 2013, 2:08 ] |
I think this one will not work sorry to say. I have seen this when they try to jail break the phone. Before some phones were able to jail break then the newer ones when tried would give this error. When you tried to connect it to itunes you could not do anything with it at all. The phone is bricked. |
| Author: | hddguy [ June 10th, 2013, 4:15 ] |
As far as I know the wipe/erasure isnt done until it is accessed remotely via the "Find My iPhone" utility, or until being restored with iTunes. |
| Author: | craig6928 [ June 10th, 2013, 9:37 ] |
if they set it up on the phone there a self destruct after to many failed passcode attempts which will wipe the phone and data clean as they tried to enter the passcode to many times and its disabled now nothing else they can do. |
