 Post subject: Toshiba THNSNF256GMCS - password
PostPosted: August 22nd, 2013, 18:01
I have drive Toshiba THNSNF256GMCS (FSGNWDM) with password locked. Have anyone experience with this drive - i need remove it.
Any hints here or to PM will be nice.
 Post subject: Re: Toshiba THNSNF256GMCS - password
PostPosted: August 23rd, 2013, 2:03
Was this drive locked by user or with default password by laptop?
I second variant , using service Tag number you can genarate the pass.
Angel Data Recovery
PostPosted: August 23rd, 2013, 3:37
How long can you wait with this case?
PostPosted: August 23rd, 2013, 7:33
Other drive works ok in laptop, so looks like it is locked by user password.
I talk with client - maybe he can wait.
PostPosted: September 12th, 2013, 17:22
Not sure but Toshiba likes rebrand others MCUs. This one is probably samsumg 830 or JMF602 . Need to research this more deeply . So, if customer need data from ssd, this, at least, gives a chance .
Angel Data Recovery
PostPosted: September 12th, 2013, 20:20
Yes, you have right, Toshiba rebrand MCU - I see only from Sandforce (many many cases, usually SSD from Macbooks are Sandofrce). And probably my case is like that.
PostPosted: September 13th, 2013, 1:13
On SandForce_Toshiba MCU is clearly written : SandForce . And it is THNSNS models . I doubt about your THNSNF. Better check that.
Angel Data Recovery
PostPosted: September 15th, 2013, 5:06
DR-Kiev you have right. This case has Marvell controller. Unfortunately still no solution.
PostPosted: September 27th, 2013, 4:05
Did you try to use PC3K Marvell VanGogh utility? Just wondering if toshiba uses same firmware.. I think it doesnt, but who knows..
PostPosted: September 28th, 2013, 11:05
Yes, of course I try it. It doesn't work.
Users browsing this forum: Google [Bot] and 16 guests
