Page 1 of 5
SSD drives is it worth to use in everyday life ?
Posted: July 12th, 2013, 19:25
by DR-Kiev
What do you think guys is SSD worth to use in everyday life? Is it realy safe and so fast and you realy can suggest to your friends to buy it instead of usual HDDs ?
What about real fault tolerance statistic and waranty 5 years of some vendors?
2 viewmax
Re: SSD drives is it worth to use in everyday life ?
Posted: July 12th, 2013, 19:54
by labtech
If they have the money, I suggest them to get a quality SSD.
Posted: July 12th, 2013, 20:53
by Dmitry Postrigan
We use SSD drives in servers under heavy load for several years. Here are my observations:
1) OCZ Vertex 3 = fast but not very reliable
2) Samsung 830 = fast and reliable
3) Intel 330 and 520 = very reliable but writes slow down a little after a while (not really an issue)
4) Mushkin Chronos deluxe = fast, not sure about reliability though, we only use them for several months.
5) Micron SLC RealSSD P300 = reliable, uber-expensive (not worth it)
For home use I would highly recommend an Intel (3xx or 5xx) or Samsung 830 SSD. I would stay away from Samsung 840 series for now as they are too fresh and I've already seen some quirks, but otherwise look very promising.
Just stay away from OCZ, Corsair, Crucial and other "PC enthusiast" brands (and perhaps Kingston too).
Posted: July 13th, 2013, 1:59
by Touchclarity
All of my 6 main DR workstations have Samsung 830 SSD's as the primary boot drive (O/S and program data only) . They are in use EVERY day and I have not yet had a problem with them.
Posted: July 13th, 2013, 14:21
by Keatah
Stay away from gamerz toys like OCZ, Crucial, Corsair, Kingston, seemingly anything with go-fast words in its name.
Intel and Samsung are best for consumer usage right now for a number of technical reasons.
Posted: July 14th, 2013, 23:15
by craig6928
OCZ Vertex 3 IS A PIECE OF CRAP badly design over heating a big issues
i rather use the old standard hard drives as they are more better.
have to say seagate hybrid ones are not bad at all
still going strong
Posted: July 15th, 2013, 6:50
by Izualim
Indeed, HHDD are not bad at all. i bought one for myself, and i have to say it's around 75% of a SSD Drive, and it uses SLC nands. nothing to complain about them.
Posted: July 23rd, 2013, 3:30
by craig6928
just like to add Kingston V Series 128GB
watched some movies on it last night
next morning.
just does not want to boot up at all total dead fuses all check out ok
another peice of crap
they are a crap design and like most ssd drives over heating is a issue
Posted: July 23rd, 2013, 4:24
by Keatah
I keep "hoping" and "wanting" to like Kingston SSD, for Kingston was a good name for RAM and their warranty was/is outstanding.
But for SSD, it's a no-go. The nand they use is rated at less than 3000 erase/write cycles.
I'm sure others in the industry are just as bad, but Kingston stands out since their PR and ad department was ohh-so brilliant and praised to high heaven the extreme durability of 3,000 write cycles! Ughh...
IMHO, the industry is pushing in the wrong direction. They are increasing density and the expense of longevity and durability. And they are having to use that very same capacity improvement to overprovision and spares to offset early cell failures.
Just make it right in the first place instead of doing all this sidestepping and dancing around.
Posted: July 23rd, 2013, 4:40
by fzabkar
Keatah wrote:I keep "hoping" and "wanting" to like Kingston SSD, for Kingston was a good name for RAM and their warranty was/is outstanding.
(128 gigabytes x 3000 cycles) / (10 years) = 105 gigabytes per day
Posted: July 23rd, 2013, 4:55
by arvika
The new nand flash chips is pice of crap - you know the "problem chip". Compnent has very very bad quality.
Posted: July 23rd, 2013, 9:06
by DR-Kiev
fzabkar wrote:(128 gigabytes x 3000 cycles) / (10 years) = 105 gigabytes per day
3000 cycles for each cell
http://cdn2.ubergizmo.com/wp-content/uploads/2013/05/endurance-samsung-mlc-vs-samsung-tlc.jpg
Posted: July 23rd, 2013, 9:15
by Doomer
FYI 105GB/day is not much
Posted: July 23rd, 2013, 11:56
by DR-Kiev
fzabkar wrote:Keatah wrote:I keep "hoping" and "wanting" to like Kingston SSD, for Kingston was a good name for RAM and their warranty was/is outstanding.
You forgot to say , to read/write only one cell you need to read/write min 4Kb page size
Posted: July 23rd, 2013, 17:14
by fzabkar
DR-Kiev wrote:fzabkar wrote:Keatah wrote:I keep "hoping" and "wanting" to like Kingston SSD, for Kingston was a good name for RAM and their warranty was/is outstanding.
I didn't forget anything, I just ignored it because the firmware and OS are optimised so that it makes essentially no difference to the calculation these days. In fact some SSDs use compression, in which case write amplification can be as low as 0.5.
Posted: July 23rd, 2013, 18:32
by Doomer
fzabkar wrote:I didn't forget anything, I just ignored it because the firmware and OS are optimised so that it makes essentially no difference to the calculation these days.
I wouldn't call it "optimized" it's just the way it works. FS driver operates in clusters, so when you work with files, even if you change one byte - the whole cluster will be updated, except for a file record that can be smaller than data cluster in size
On a side of SSD it depends greatly on firmware. There were SSDs that split data by byte between two pages, so when you want to write one byte of data (from user perspective) and a data cluster (from FS driver perspective) at least two pages will be updated on that particular SSD, because data will be split evenly between two pages, that's just a real life example, all SSDs are different inside
There are some SSDs that report number of erase cycles for the whole drive: essentially it represents number of erase cycles on all data cells (it is possible to calculate this value because of wear leveling mechanism)
Some SSDs even show % of life left based on that erase cycles number and theoretical SSD usage per day
End user can rely on those values and even try to calculate SSD's "life expectancy" based on Power On hours and erase cycles
Posted: July 24th, 2013, 1:36
by craig6928
so what the public dont know its a dirty tricks with the ssd companys who make them
find some cheap crappy chips
so does this mean the drives after say 3000 erase/or write cycles
automatic shut down or just burn out
its a bit like printers you get so many prints and clean
before the printer shuts down for good.
its dirty tricks from companys that make them
its a way to sell more products
Posted: July 24th, 2013, 1:54
by Keatah
SSD's in idea circumstances go to read-only when their lifespan of write/erase is used up.
It's not an intentional dirty trick or scam by any company. It's simply a company's natural psychotic drive for profit at any cost that creates these low quality SSDs. They spend seemingly extraordinary amounts of money and time on R&D to try and produce these things at the lowest possible cost.
Saving $0.05 USD on a NAND chip can mean millions in extra profit. At the cost your data of course..
Posted: July 24th, 2013, 3:32
by fzabkar
Keatah wrote:Saving $0.05 USD on a NAND chip can mean millions in extra profit.
What percentage of SSD faults are the result of NAND flash failures?
AFAICT from various storage forums, including SalvationData's, the most common failure mode appears to involve corruption of the Flash Translation Layer. In such cases there is no actual failure in any physical component. Can anyone enlighten me if I'm wrong?
Posted: July 24th, 2013, 5:03
by arvika
In modern SSD and flashes (pendrive, card memory) chip failure is quite common comparing to the older devices.
