Scorpion wrote:Sounds like a good solution.
How much in % such solution can save from the total recovery price?
I am not sure I understand your question, could you say it in a different way?
I will have a stab anyway..
If you mean how much could you charge the customer, and how much would the person you send the dumps charge you, so you can work out a profit margin.. well that is up to the person/persons you decide to do business with, and it would be different probably for everyone.
say Arvika asked from you $75, you ask the customer for $100 and you get $25.
If you are asking what a going rate for DR on flash drives are, well that's going to be different based on the business, location, the actual engineer, quantity of cases etc. etc..
That discussion has been had many times with probably no real value.
But, I have found once you start solving cases, word gets around, suddenly it seems like flash drives are the most unreliable media ever
(meaning you will start to get a lot of enquiries)
I don't know if you are an IT business or what, but a quite sensible path could be:
1. buy NAND Reader for.. IIRC $210
2. Read customers chips, send dumps of chips to a DR Engineer that you can strike up a deal with.
3. Start to get increased business/or not to see if added outlay is acceptable
4. if 3 is true, buy additional adapters for LGA etc as you can afford
5. if 3 is true, and getting better, then
6. Outlay for a licence, and start learning how to do it, while still outsourcing the hard ones or getting support from community to keep a quick turnaround of cases..
7. if 3 is true STILL, buy another solution as well such as ACE Laboratorys PC-3000 Flash SSD Edition.
8. Retire on your own Island in a Mansion and 12 beautiful ladies
Ok, exaggerated one of those steps...
I know how bad it is to start on a budget. I borrowed to outlay on a Salvation Data Flash Doctor. BIG MISTAKE. Tool is not exactly useful. wasted Money and lost income at the same time because could not solve cases. Could not afford to do anything else for quite some time...
good luck
