 Post subject: adata c906/8GB doesn't detect at all
PostPosted: August 3rd, 2013, 3:13
good morning ..
i have this adata c906/8GB that doesn't detect at all ...
plugging the drive to a linux machine , will add nothing to the dmesg messages , so it really doesn't detect .
please , any ideas ?
thanks
 Post subject: Re: adata c906/8GB doesn't detect at all
PostPosted: August 3rd, 2013, 3:16
Desolder NAND, read it by SC or PC3K or other reader for NAND flash, remove mixes and use assembler to make an image. Enjoy your data :)
PostPosted: August 3rd, 2013, 3:19
First, take off the blue shield and inspect closely the USB connector where it solders to the mainboard.
I have also been getting a lot of SM3257EN Q controllers in and there is many issues with recovering such as bank sizes.
or unsolder NAND and read it / recover data
PostPosted: August 4th, 2013, 0:03
i think read chip and assemble is the best. usual SM3257 with bad firmware make it can't detect
data recovery service[/b]
PostPosted: August 4th, 2013, 7:03
Generally the SM3257 will at least flash the LED and the PC will have some reaction to the device
That's why I'm suggesting to look there first as a quick measure. About 10% of cases (not including the ones the user knows they broke the connector) are actually that and it I'd and easy fix
Btw which tools for flash do you have?
PostPosted: August 4th, 2013, 14:53
thank you for your answers ..
te connecter is fine , unfortunatly
the problem is elsewhere ... case was outsourced ..
i will stop accepting ssd/flash cases :cry:
thank you again
PostPosted: August 4th, 2013, 15:51
I wouldn't be so hasty to stop accepting them. Just have a quick and defined process. If you can fix the 10% - 20% that don't need NAND read such as connectors and outsource the rest you still get a bit. Depends how you are doing with other things - if you have time etc - ultimately a business decision.
Users browsing this forum: Ahmed Saeed and 118 guests
