| disassembly monolith flash drive http://forum.hddguru.com/viewtopic.php?f=10&t=26557 |
Page 1 of 1 |
| Author: | networkpc3000 [ August 2nd, 2013, 22:26 ] |
| Post subject: | disassembly monolith flash drive |
more details photo http://www.rflashdata.com |
| Author: | HaQue [ August 2nd, 2013, 23:09 ] |
| Post subject: | Re: disassembly monolith flash drive |
Nice data surely not recoverable after this.. this is a demo of what internals look like isn't it? What magnification is that at around 100-200x ? really cool! |
| Author: | networkpc3000 [ August 3rd, 2013, 2:30 ] |
i think data still can be recoverable. as chip no damaged. for this case. it's bad donor drive. pinout made. but i have problem with read dump so i want to check inside connection. how many X i am no sure. around 60~80X only |
| Author: | HaQue [ August 3rd, 2013, 2:39 ] |
I hope you can get data, good luck. So how do you connect wires to something so small. I thought it was hard enough to connect to the regular row of 40 pads on the outside of the monolith, but this is a whole different level. It is really interesting to see things Ill never see in the flesh, so thanks again. |
| Author: | networkpc3000 [ August 3rd, 2013, 22:56 ] |
this case connect wire easy. http://www.rflashdata.com/kingston-1g-sd/ it's hard for me. i make this solution with luck. need improve skill for process such case. as many case like this. |
