| Amazon Basic 16GB SD-Card ? [ Recoverable ] http://forum.hddguru.com/viewtopic.php?f=10&t=26589 |
Page 1 of 1 |
| Author: | Amarbir[CDR-Labs] [ August 6th, 2013, 8:24 ] |
| Post subject: | Amazon Basic 16GB SD-Card ? [ Recoverable ] |
Hi All , Got This Case .The Picture Of The Card Are Attached .Its a 16 GB " Looks Like Sandisk But i Cannot Confirm This " .Has Anyone Worked On This .Chip Seems To Be BGA Type .
| Author: | HaQue [ August 6th, 2013, 10:28 ] |
| Post subject: | Re: Amazon Basic 16GB SD-Card ? [ Recoverable ] |
hi, you may be right as a sandisk, but for a hint look here: http://flash-extractor.com/library/No%20Name/No%20Name%20SD/ and here: http://flash-extractor.com/library/No%20Name/No%20Name%20SD/SD_5/SD_5__98_de_95_32__1x2 I think if you read chips, may be clearer. what tool do you have? |
| Author: | Amarbir[CDR-Labs] [ August 6th, 2013, 10:58 ] |
HaQue wrote: hi, you may be right as a sandisk, but for a hint look here: http://flash-extractor.com/library/No%20Name/No%20Name%20SD/ and here: http://flash-extractor.com/library/No%20Name/No%20Name%20SD/SD_5/SD_5__98_de_95_32__1x2 I think if you read chips, may be clearer. what tool do you have? First Of All Hello , I Am a Very Old Member Here But In The Past 2 Years Very Less Post .I Have PC 3000 Flash Since a Long Time .It Think Its This -> http://flash-extractor.com/library/No%2 ... 0SD/SD_54/ @ All, Hi everyone How Are You Folks .I Am Also Looking For a BGA Adapter For This To Convert To TSOP Type Something Like This
| Author: | arvika [ August 6th, 2013, 13:49 ] |
Amarbir wrote: HaQue wrote: Confirm. It should be solution from this link or similar. |
| Author: | Touchclarity [ August 6th, 2013, 15:39 ] |
Amarbir wrote: I Am Also Looking For a BGA Adapter For This To Convert To TSOP Type Something Like This Amarbir..... if you update your PC3000 Flash reader, you can also purchase the correct adapters for these chips.... lot easier than soldering the chips to a NAND boards ACE provided for the earlier reader.... http://www.pc-3000flash.com/eng/flashwork.php |
| Author: | fzabkar [ August 6th, 2013, 15:43 ] |
"S4T8030" looks like a Samsung part numer. For example, "S4LN045X01-8030" is Samsung's MEX flash controller. |
| Author: | GreyDKang [ August 8th, 2013, 2:57 ] |
SDC1830- Phison 8030 SDC801-806 - Phison 8001-8006. SD3820 -Phison 8032 |
| Author: | Amarbir[CDR-Labs] [ August 8th, 2013, 3:06 ] |
GreyDKang wrote: SDC1830- Phison 8030 SDC801-806 - Phison 8001-8006. SD3820 -Phison 8032 Well, Here Speaks The Man ,How Are You These Days |
| Author: | hddguy [ August 8th, 2013, 6:30 ] |
http://www.flash-extractor.com/manual/problem_chips/ |
| Author: | GreyDKang [ August 9th, 2013, 4:35 ] |
hddguy wrote: http://www.flash-extractor.com/manual/problem_chips/ Strange thing, but from card these chips are reading well often. |
