 Post subject: Amazon Basic 16GB SD-Card ? [ Recoverable ]
PostPosted: August 6th, 2013, 8:24
Hi All ,
Got This Case .The Picture Of The Card Are Attached .Its a 16 GB " Looks Like Sandisk But i Cannot Confirm This " .Has Anyone Worked On This .Chip Seems To Be BGA Type .
 Post subject: Re: Amazon Basic 16GB SD-Card ? [ Recoverable ]
PostPosted: August 6th, 2013, 10:28
hi,
you may be right as a sandisk, but for a hint look here: http://flash-extractor.com/library/No%20Name/No%20Name%20SD/
and here:
http://flash-extractor.com/library/No%20Name/No%20Name%20SD/SD_5/SD_5__98_de_95_32__1x2
I think if you read chips, may be clearer.
what tool do you have?
PostPosted: August 6th, 2013, 10:58
HaQue wrote:
hi,
and here:
First Of All Hello ,
I Am a Very Old Member Here But In The Past 2 Years Very Less Post .I Have PC 3000 Flash Since a Long Time .It Think Its This -> http://flash-extractor.com/library/No%2 ... 0SD/SD_54/
@ All,
Hi everyone How Are You Folks .I Am Also Looking For a BGA Adapter For This To Convert To TSOP Type Something Like This
PostPosted: August 6th, 2013, 13:49
Amarbir wrote:
HaQue wrote:
Confirm. It should be solution from this link or similar.
PostPosted: August 6th, 2013, 15:39
Amarbir..... if you update your PC3000 Flash reader, you can also purchase the correct adapters for these chips.... lot easier than soldering the chips to a NAND boards ACE provided for the earlier reader....
http://www.pc-3000flash.com/eng/flashwork.php
East Anglian Data Recovery Services
http://www.eadr.co.uk
"If it's your only copy - then it's not a backup!"
PostPosted: August 6th, 2013, 15:43
"S4T8030" looks like a Samsung part numer.
For example, "S4LN045X01-8030" is Samsung's MEX flash controller.
PostPosted: August 8th, 2013, 2:57
SDC1830- Phison 8030
SDC801-806 - Phison 8001-8006.
SD3820 -Phison 8032
PostPosted: August 8th, 2013, 3:06
SD3820 -Phison 8032
Well,
Here Speaks The Man ,How Are You These Days :mrgreen:
PostPosted: August 8th, 2013, 6:30
http://www.flash-extractor.com/manual/problem_chips/
PostPosted: August 9th, 2013, 4:35
Strange thing, but from card these chips are reading well often.
Users browsing this forum: Google [Bot] and 18 guests
