 Post subject: Acelab PC-3000 Flash SSD Edition which versions
PostPosted: August 14th, 2013, 18:52
hello so just wondering how many people use the below tool still
it says that its flash ssd edition tool
but we notice that there is two version of this
is this correct
is it worth sticking with this version rather then upgrading again
 Post subject: Re: Acelab PC-3000 Flash SSD Edition which versions
PostPosted: August 14th, 2013, 19:41
Reader is v2.0. Last is 3.0 has external adapter for connect TLGA52 adapters.
data recovery service[/b]
PostPosted: August 14th, 2013, 23:52
so other then that not much diffrence with the new version.
only adapter connected added.
same software.
PostPosted: August 15th, 2013, 3:14
The software doesnt depends on version of the reader, must work with all versions.
PostPosted: August 15th, 2013, 3:59
I have both readers..... software is the same.... :D
http://www.eadr.co.uk
PostPosted: August 15th, 2013, 5:43
ok thanks for the update we stick with this version :D
PostPosted: August 15th, 2013, 9:56
I think future update v2.0 version can't use some function.
