HDD GURU FORUMS
http://forum.hddguru.com/
Toshiba THNSNF256GMCS - password
http://forum.hddguru.com/viewtopic.php?f=10&t=26707
Page 1 of 1
Author:  arvika [ August 22nd, 2013, 18:01 ]
Post subject:  Toshiba THNSNF256GMCS - password
I have drive Toshiba THNSNF256GMCS (FSGNWDM) with password locked. Have anyone experience with this drive - i need remove it.
Any hints here or to PM will be nice.
Author:  DR-Kiev [ August 23rd, 2013, 2:03 ]
Post subject:  Re: Toshiba THNSNF256GMCS - password
Was this drive locked by user or with default password by laptop?
I second variant , using service Tag number you can genarate the pass.
Author:  bubaleh [ August 23rd, 2013, 3:37 ]
How long can you wait with this case?
Author:  arvika [ August 23rd, 2013, 7:33 ]
Other drive works ok in laptop, so looks like it is locked by user password.
I talk with client - maybe he can wait.
Author:  DR-Kiev [ September 12th, 2013, 17:22 ]
Not sure but Toshiba likes rebrand others MCUs. This one is probably samsumg 830 or JMF602 . Need to research this more deeply . So, if customer need data from ssd, this, at least, gives a chance .
Author:  arvika [ September 12th, 2013, 20:20 ]
Yes, you have right, Toshiba rebrand MCU - I see only from Sandforce (many many cases, usually SSD from Macbooks are Sandofrce). And probably my case is like that.
Author:  DR-Kiev [ September 13th, 2013, 1:13 ]
On SandForce_Toshiba MCU is clearly written : SandForce . And it is THNSNS models . I doubt about your THNSNF. Better check that.
Author:  arvika [ September 15th, 2013, 5:06 ]
DR-Kiev you have right. This case has Marvell controller. Unfortunately still no solution.
Author:  bubaleh [ September 27th, 2013, 4:05 ]
Did you try to use PC3K Marvell VanGogh utility? Just wondering if toshiba uses same firmware.. I think it doesnt, but who knows..
Author:  arvika [ September 28th, 2013, 11:05 ]
Yes, of course I try it. It doesn't work.
http://www.phpbb.com/
