 Post subject: Kingston 8GB MicroSD HC won't show up on Linux
PostPosted: September 10th, 2013, 2:16
Client reports that nothing shows up on their system - was hoping it was simply a case of an accidentally formatted/deleted files ( hah! ).
Tried a few different card readers, only thing that came up was:
[1152533.815590] Sense Key : Illegal Request [current]
[1152533.815594] sd 8:0:0:0: [sdb]
[1152533.815598] Add. Sense: Invalid command operation code
[1152533.815602] sd 8:0:0:0: [sdb] CDB:
[1152533.815604] Read(16): 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[1152533.816832] sd 8:0:0:0: [sdb] Invalid command failure
[1152533.816836] sd 8:0:0:0: [sdb]
[1152533.816839] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[1152533.816842] sd 8:0:0:0: [sdb]
[1152533.816845] Sense Key : Illegal Request [current]
[1152533.816849] sd 8:0:0:0: [sdb]
[1152533.816853] Add. Sense: Invalid command operation code
[1152533.816857] sd 8:0:0:0: [sdb] CDB:
[1152533.816859] Read(16): 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: Kingston 8GB MicroSD HC won't show up on Linux
PostPosted: September 10th, 2013, 2:31
Probably controller is dead. Need read dumps directly form nands.
PostPosted: September 10th, 2013, 2:51
Anyone around here do that as a service?
Here's the syslog output as well;
Sep 10 16:49:43 workbox kernel: [1155657.796384] usb 1-1.2: new high-speed USB device number 13 using ehci-pci
Sep 10 16:49:43 workbox kernel: [1155657.899912] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=0159
Sep 10 16:49:43 workbox kernel: [1155657.899920] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 10 16:49:43 workbox kernel: [1155657.899925] usb 1-1.2: Product: USB2.0-CRW
Sep 10 16:49:43 workbox kernel: [1155657.899929] usb 1-1.2: Manufacturer: Generic
Sep 10 16:49:43 workbox kernel: [1155657.899933] usb 1-1.2: SerialNumber: 20071114173400000
Sep 10 16:49:43 workbox kernel: [1155657.915809] scsi15 : usb-storage 1-1.2:1.0
Sep 10 16:49:43 workbox mtp-probe: checking bus 1, device 13: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2"
Sep 10 16:49:43 workbox mtp-probe: bus: 1, device: 13 was not an MTP device
Sep 10 16:49:44 workbox kernel: [1155658.914604] scsi 15:0:0:0: Direct-Access     Generic- Multi-Card       1.00 PQ: 0 ANSI: 0 CCS
Sep 10 16:49:44 workbox kernel: [1155658.916074] sd 15:0:0:0: Attached scsi generic sg2 type 0
Sep 10 16:49:50 workbox kernel: [1155664.839065] sd 15:0:0:0: [sdb] Attached SCSI removable disk
Sep 10 16:49:53 workbox kernel: [1155667.821518] usb 1-1.2: USB disconnect, device number 13
PostPosted: September 10th, 2013, 6:46
HaQue maybe, he's a fellow Oz and generally all round good egg :)
Kern
Голод не тётка!
PostPosted: September 10th, 2013, 20:42
Thanks, he's now in touch with me and we're sorting out what we can be done.
Regards,
Paul.
Users browsing this forum: No registered users and 24 guests
