Kingston SSDNow - Soft read error rate - values please!!
http://forum.hddguru.com/viewtopic.php?f=10&t=27279
Author:  jorgk3 [ November 15th, 2013, 4:40 ]
Post subject:  Kingston SSDNow - Soft read error rate - values please!!
I am trying to figure out which soft read error rate (ECC-corrected bit errors) is "normal" for the drive.
The normalised "soft read error value" is calculated as follows:
10 * LOG (bits read / bit errors), so in the example below:
10 * LOG (2910250 * 512 * 8 / 158120) = 48.77.
I'd just like to know what value other people with the same drive are getting. I read here
http://www.kingston.com/en/ssd/enterprise/best_practices/enterprise_versus_client_ssd that for MLC NAND, the value of the BER should be around 10^(-7). Mine is a 10^(-4.8 ) , so a little above 10^(-5).
So if people who have the same type of drive could kindly post their model and the value of SMART attribute 13. Thank you!!
Here's my complete SMART data for my SSDNow 300 V - SV300S37A/60G:
SMART READ DATA
   Revision: 10
   Attributes List
     1: (SSD Raw Read Error Rate)               Normalized Rate: 100  Sectors Read: 2910250 Read Errors: 0
     5: (SSD Retired Block Count)               Spare blocks remaining 100%  Retired Block 0
     9: (SSD Power-On Hours)                    Value 100  Total 233 hrs 7 mins
    12: (SSD Power Cycle Count)                 Power Cycle Life Remaining 100%  Number of power cycles 127
    13: (SSD Soft Read Error Rate)              Normalized Error Rate 48 Sectors Read 2910250 Soft Read Error Count 158120
   100: (SSD GBytes Erased)                     Gigabytes Erased  269
   170: (SSD Number of Remaining Spares)        Number of remaining spares 1760
   171: (SSD Program Fail Count)                Program Error Count 0
   172: (SSD Erase Fail Count)                  Erase Error Count 0
   174: (SSD Unexpected power loss count)       Unexpected power loss Count 31
   177: (Wear Range Delta)                      Wear Range Delta 0%
   181: (Program Fail Count)                    Program Error Count 0
   182: (Erase Fail Count)                      Erase Error Count 0
   184: (SSD End to End Error Detection)        Normalized Value 100 IOEDC Error Count 0
   187: (SSD Reported Uncorrectable Errors)     Normalized Value 100  lifetime URAISE Errors 0
   189: (Unrecognized Attribute)                Value:  26 Raw Data: 1a 00 35 00 13 00 00
   194: (SSD Temperature Monitoring)            Normalized temp 26   Current 26  High 53 Low 19
   195: (SSD ECC On-the-fly Count)              Normalized Value 120   Sectors Read 2910250  UECC Count 0
   196: (SSD Reallocation Event Count)          Normalized Value 100   Reallocation Event Count 0
   198: (SSD Uncorrectable Sector Count)        Normalized Value 100   Uncorrectable Sector Count 0
   199: (SSD SATA R-Errors Error Count)         Normalized Value 200   SATA RError Count 0
   201: (SSD Uncorrectable Soft Read Error Rate)Normalized Value 120  Sectors Read 2910250  Uncorrectable Soft Error Count 0
   204: (SSD Soft ECC Correction Rate (RAISE)   Normalized Value 120  Sectors Read 2910250  Soft ECC Correction Count 0
   230: (SSD Life Curve Status)                 Normalized Value 100
   231: (SSD Life Left)                         Life Remaining 100%
   232: (Available Reserved Space)              Available Reserved Space 0 (GB)
   233: (SSD Internal Reserved)                 272
   234: (SSD Internal Reserved)                 218
   241: (SSD Lifetime writes from host)         lifetime writes   218
   242: (SSD Lifetime reads from host)          lifetime reads   264
