 Post subject: Ultrabook SSD , Power on and RDY but bsy when access
PostPosted: November 18th, 2013, 7:43
I have a SONY Vaio Ultrabook SSD Toshiba THNSNS128GCSP BSY, unable to access the data.
Power on, rdy but bsy as soon as trying to access it. No id.
Anyone have solution? Thanks
 Post subject: Re: Ultrabook SSD , Power on and RDY but bsy when access
PostPosted: November 18th, 2013, 8:09
Hi TerraNova
What form factor is the SSD?
Some of the early uSata models (not in metal case) used in Sony Z-Series often need a re-flow due to the battering they get being located underneath the touch pad.
Unfortunately the Toshiba controller used in these is just a Re badged SandForce 2281 controller..
It is more than likely that the fault you are experiencing is the well known SandForce "Panic lock"
The drive should be repairable using a SandForce bootable Firmware update/ repair tool but this is a destructive process...
As far as I know there is no means of recovering the data from these..
Fingers crossed someone proves me wrong.. :?
PostPosted: November 18th, 2013, 9:18
Hi thanks for your reply, its a 2.5" in aluminium case form factor.
PostPosted: November 18th, 2013, 9:27
damn... you could try it in a reflow oven,, but im doubtful it would be a dry joint on that model..
PostPosted: November 18th, 2013, 9:38
thanks mate will give it a try.
Users browsing this forum: No registered users and 17 guests
