| how to unlock a password protected locked intel ssd ? http://forum.hddguru.com/viewtopic.php?f=10&t=27420 |
Page 1 of 1 |
| Author: | dani0160 [ November 29th, 2013, 20:44 ] |
| Post subject: | how to unlock a password protected locked intel ssd ? |
Hi I've got a problem with my Intel X25-M 80GB ssd drive that was in one of my laptops (Lenovo). Since I've got a few laptops (work and stuff) i didn't touch this laptop a while and i forgot my passwords in this laptop. i did changed the master password of the ssd and encrypted the data. i did a huge search in the web and i couldn't found a solution to unlock an ssd that is locked (and his master pass has changed) really !!! I've tried anything (partition magic, ubcd, HDDErase, etc....) and i cant remove the lock. i don't care about the data inside. if anyone have any advice, i would welcome it ..... because i really close to make it a door stopper |
| Author: | arvika [ November 30th, 2013, 4:57 ] |
| Post subject: | Re: how to unlock a password protected locked intel ssd ? |
Take this SSD and go to local DR company, they should can remove the password. |
| Author: | dani0160 [ November 30th, 2013, 9:23 ] |
with the money that ill need to pay them, I can buy 3 of this drives as I said I don't need the data..... so I don't want to spend any money on this drive. |
| Author: | Tomset [ November 30th, 2013, 9:37 ] |
* Run Secure Erase https://downloadcenter.intel.com/Detail ... ldId=18455 |
| Author: | dani0160 [ November 30th, 2013, 12:32 ] |
tried it already, can't run it without the pass. I actually was able to secure erase the drive with some other tool but it remain locked. you need the pass to be able to use the drive again. so.... the problem remains the same |
| Author: | DR-Kiev [ December 1st, 2013, 8:26 ] |
dani0160 wrote: with the money that ill need to pay them, I can buy 3 of this drives as I said I don't need the data..... so I don't want to spend any money on this drive. Just for repair that price nonsense. May be guys who quoted you meant Data Recovery process? Unlocking your SSD intel drive is pretty simple with proper hw tool, but personaly me wouldn't work with guys who "forgot the password" due , it could be just stolen. |
| Author: | dani0160 [ December 1st, 2013, 14:38 ] |
thanks 4 your answer DR-Kiev.... I'm not an expert but from the research that I did online, hw solution is not that simple. from what im understood even if you physically change the controller in the ssd, it will remain locked. so if you can give me some name of a tool that can do or some instructions, it would be great .... and about the "forgot" stuff ..... I have the receipt |
| Author: | DR-Kiev [ December 2nd, 2013, 11:54 ] |
dani0160 wrote: thanks 4 your answer DR-Kiev.... I'm not an expert but from the research that I did online, hw solution is not that simple. from what im understood even if you physically change the controller in the ssd, it will remain locked. so if you can give me some name of a tool that can do or some instructions, it would be great .... and about the "forgot" stuff ..... I have the receipt http://www.pc-3000flash.com/eng/ver64.261113.php You can buy it and try . It works good with password locked Intel SSD (Postville core based) Of cource you need to learn to work on it too. |
| Author: | carlosjml4 [ February 25th, 2015, 8:04 ] |
Hello , Dani0160 , best regard. I would like to ask if you can unlock the intel was sdd . I work with computers and I tecnico en unproblema same password lock . Thank You! |
