Data damaged in Polaroid brand 32GB microSD
Posted: January 20th, 2014, 6:16
by jzchen
I had a lot of photos taken using a Samsung SIII phone, and then I made the mistake of putting the phone in a bag with clothes while swimming. It must have gotten bumped around or something, because now a whole lot of the more recent pictures are missing. The last pictures I can see are from a trip several months/possibly years ago.
There is no physical damage to the card, just damaged data. When I insert the card in an adapter and into the computer it asks me to format it, which I do not do.
I was wondering if I could be directed to an expert who can possibly retrieve pictures for me, because one of them was a picture my 8 yr old boy took and won an award for in our local school disctrict.
Thank you very much, and take care.
Just in case it is labeled Polaroid BY PNY on the SD adapter, has the class 10 label, and on the back says:
UD32G10000BMC8RB
7832086A 3112
Made in Korea
Re: Data damaged in Polaroid brand 32GB microSD
Posted: January 21st, 2014, 7:58
by D.I.T
Data Recovery Engineer can help you with recover all your files so find someone near you I only want to know if the device shows its full capacity the data is recoverable.
Posted: January 21st, 2014, 12:01
by jzchen
Thanks D.I.T.!
I'm afraid Windows would say format as soon as I insert it. The phone says it is damaged, but still is able to show the old photos. I was afraid to cause any more damage so I didn't really try to do much more.
I did see at a local Fry's they do data recovery. But I had a bad experience with the first P4 build they couldn't fix. Finally found out needed to install correct chipset driver, they were a waste of money...
Posted: January 22nd, 2014, 6:56
by Matiw
Could the old photos that you see in the Camera be those that are saved in the Cameraºs built-in memory ? Have you tried another camera ?
Posted: January 22nd, 2014, 7:30
by HaQue
Yes a proper data recovery person may be able to recover. Flash drives are a very "iffy" thing to recover, so many different flash chips and controller chips and quality etc.
I would not play with it.. find a real data recover company. ask them if they do proper recovery, and if they are quite experienced at it.
I had the same issue with a Sandisk MicrSD Card. The following worked for me:
1. install "partition find and mount" on your PC.
2. insert card into PC, and ignore the "format" message, but do NOT click it off.
3. open partition find and mount, hopefully you see your drive there. do not search for a partition, just select your card and take an image of it and save to your PC. This is a copy of all the sectors of the card. Now try some data recovery software on the image. such as GetDataBack.
Posted: January 23rd, 2014, 7:34
by jzchen
Thank you guys for the responses!
HaQue wrote:Yes a proper data recovery person may be able to recover. Flash drives are a very "iffy" thing to recover, so many different flash chips and controller chips and quality etc.
Again, thank you for the help!!! I actually went over some advice you gave me before about a Ford Navigation issue I had, and clicked a link to another forum and found some advanced information that was kind of above me, (although I have worked with a hex editor in the past.)
I was hoping Sandisk wouldn't likely have the same issues as this relatively inexpensive card I bought on sale at Fry's, but now you have got me concerned. (My wife has a trial to Amazon Prime and I found Amazon had the cheapest price using search engines Shopzilla, Bizrate, Pricegrabber, Nextag, and Froogle, so I ordered an Extreme Pro 16GB card on the 17th.) It says on the packaging that it is "WATER PROOF" and "TEMPERATURE PROOF", with reference to a webpage for details, besides the fact that it rated up to 95MB/s read, 90MB/s write speed. It came Tuesday, and I opened it excited that I had a memory card again to store.
Low and behold inside was a little paper saying "FREE DOWNLOAD 1-Year subscription of RescuePRO Deluxe recovery software". I decide to try it. It recognizes two items that seem to be the same SD card, one says 32GB, and the other I think unformatted. I try the 32GB one as it seems to be the better choice. It has three options for retrieval, but the instructions note them a little differently. First is pictures, second is videos, third is all/all other files. I tried them in order as pictures was the most important to me, videos second, and all other files third. On the actual software the third selection is "All", and in the instructions it says "all other", but the correct functionality seems to be all. I noticed in the lower left of the window it notes any "read errors", and I noticed the number was 0 in each of the three options that I tried. It automatically saves the retrieved files to an output directory in each case, with a date stamp. I then used the fourth option to create an image backup. Overall I am very happy with the results....
Matiw wrote:Could the old photos that you see in the Camera be those that are saved in the Cameraºs built-in memory ? Have you tried another camera ?
This is a great idea! I didn't think about trying in another camera, and I'm not sure exactly where those other pictures were, now that I think about it. But, now that I think about it a little more, it might be risky inserting into another camera as it might "prepare" it for image/video storing, and possibly damage some of those items that I am trying to retrieve in the process. I really do appreciate the ideas/thoughts though!!!
