HDD GURU FORUMS
http://forum.hddguru.com/
sandisk cruzer switch flash drive
http://forum.hddguru.com/viewtopic.php?f=10&t=27830
Page 1 of 1
Author:  emkanapot [ January 27th, 2014, 11:25 ]
Post subject:  sandisk cruzer switch flash drive
hi,
i have cruzer switch flash drive from client and i have a flash reader. i tried to take the nand chip out but i didn't see it. i don't know where it is. i also attach a picture after removing the case. could anybody advise me how to do data recovery from this drive?
regards,
Author:  labtech [ January 27th, 2014, 13:10 ]
Post subject:  Re: sandisk cruzer switch flash drive
Search monolith
Author:  arvika [ January 27th, 2014, 14:31 ]
Does the traces under top layer look like this:
http://www.odzyskiwanie-danych.com.pl/i ... arvika.jpg
Author:  networkpc3000 [ January 28th, 2014, 4:50 ]
hi,
you had to remove black cover and soldering wire from USB drive PCB to flash reader.
http://www.rflashdata.com/2461f7010074- ... r-pop-16g/
Author:  HaQue [ January 28th, 2014, 10:10 ]
What they said. And also, if you want to see where the NAND chip is, for a look at exactly how these are made, with good pics, you should search for the links I posted in one of my recent posts, I think in Lounge or flash.
It will show you exactly what you have there.
Author:  emkanapot [ January 31st, 2014, 2:44 ]
thank you.
http://www.phpbb.com/
