| Compact Flash with 2 partitions howto coppy ? http://forum.hddguru.com/viewtopic.php?f=10&t=27989 |
Page 1 of 1 |
| Author: | 123funske [ February 17th, 2014, 14:56 ] |
| Post subject: | Compact Flash with 2 partitions howto coppy ? |
Hi everybody, I need to copy more then 500 cf-cards. Managed to do it with HDD raw copy tool. But... I'm looking to automate this job. Is there a commandline interface to copy for ex. 2 partitions to a new cf-card? This is how de cf-card is partitionned: Partition ### Type Size Offset ------------- ---------------- ------- ------- Partition 1 Primary 11 MB 31 KB Partition 0 Extended 992 MB 11 MB Partition 0 Logical 992 MB 11 MB DISKPART> Does anyone know how to clone this disk in a way that can be automated.. ? Thanks for the effort, Regards, |
| Author: | fzabkar [ February 17th, 2014, 18:09 ] |
| Post subject: | Re: Compact Flash with 2 partitions howto coppy ? |
You could use DD in Linux. |
| Author: | HaQue [ February 17th, 2014, 19:37 ] |
+1 for DD, and a bash script or whatever. make sure you test the first ones, and also test if you have any different SD Cards, even slight differences. I had issues with cloning/re-imaging cards that were slightly smaller than the original, as they are not all the same size, they are best described as approxiamately the same size. |
| Author: | 123funske [ February 18th, 2014, 11:22 ] |
Thanks for u reply's. I'm a windows guy,.... is there a windows equivalent for dd ?? I have to dig into it otherwise, use a bootable linux. w'll see.. . |
| Author: | HaQue [ February 18th, 2014, 17:26 ] |
funnily enough if you chuck "windows equivalent for dd " you do get some options I think I saw a dd for windows quite a while ago, so you may be lucky. But if you need to use a Linux boot CD I think it shouldn't be too bad to get it figured out. you can always post your challenges back here to get where you need. good luck |
