Your photos are too dark to make out some of the components. Do you have access to a CCD scanner, and, if so, could you scan your PCB at 1200dpi?
Otherwise, could you measure the resistance of the diode D1 near the SATA power connector?
If D1 is OK, could you then measure the voltages at coils L2, L3, and L4?
Also measure the voltages at U19.
If these are OK, then we could try to get some terminal output from what appear to be the RS232 Tx/Rx/Gnd pins. You will need a USB-TTL serial adapter for this.
Could you supply clearer shots of the areas of the PCB in the attachments? What are the markings on U17 and U19? Are there any markings around the serial Tx/Rx pins?
- Attachments
- serial_Tx_Rx.jpg (18.91 KiB) Viewed 14478 times
- Vregs.jpg (139.46 KiB) Viewed 14478 times
- 5V-TVS.jpg (18.63 KiB) Viewed 14478 times
