 Post subject: SD Card Issue
PostPosted: September 6th, 2014, 13:01
Hi all,
I have a micro-sdhc card (SanDisk Ultra 8GB)
The card worked perfectly, and I used it several times over the last week, but unfortunately I didn't make a backup (was waiting on a new card) and now the card doesn't seem to work. It's not recognised on any device (tried several pc's etc.). Sometimes I get the message that the SD card is not recognised, but that's it.
Is there any way to recover a card like this?
 Post subject: Re: SD Card Issue
PostPosted: September 6th, 2014, 18:01
take it to Sean at pcimage
PostPosted: September 6th, 2014, 18:17
Thanks for the idea, seems like a good service, however it's a little expensive so maybe as a last resort...
Is there anyway to attempt this myself, or a cheaper option maybe?
PostPosted: September 7th, 2014, 0:18
Ok, then you might be lucky and be able to take an image of the complete drive, then either use Partition find an mount to find the partition and mount it to recover files. Use DMDE to try and take an image as I described here:
http://forum.hddguru.com/viewtopic.php?f=10&t=29313&p=202395&hilit=dmde#p202395
PostPosted: September 7th, 2014, 11:56
Thank you again, I will try that and report back!
PostPosted: September 7th, 2014, 12:06
No luck unfortunately, nothing recognisd...
I'v asked for a quote from the people you mentioned, so I may go down this route as nothing else seems to be working!
Thanks again
PostPosted: September 8th, 2014, 4:12
If you can not recognize SD is not DIY case.
contact with Sean on pcimage
luky
Users browsing this forum: No registered users and 122 guests
