 Post subject: 32gig CF card appearing as 894mb
PostPosted: October 5th, 2014, 19:18
Compact Flash card seems to be seen as 894mb.
It is supposed to be a 32GB.
Was used normally in Video camera.
Upon transfer to PC ready for editing it has lost it's partition. Now seen as 894mb!!
I wanted to make a Clone to recover data from it with HHD Raw copy tool, but it seems to only be 894mb still.
Any utility out there get a RAW data dump of a Compact Flash. Without removal of NAND chips..
Or is Raw chip and mix data is the next step...
Controller is SM2232T
4 NAND chips 29F64G08CBAAA
 Post subject: Re: 32gig CF card appearing as 894mb
PostPosted: October 5th, 2014, 19:58
Any Suggestions Anyone?
PostPosted: October 6th, 2014, 0:27
Most likely controller's firmware has become corrupt. Not much can be done there. The only feasible solution is data recovery by a very experienced specialist via NAND dump and data reconstruction. This config is not easy to recover due to complexities in how data is recorded.
PostPosted: October 6th, 2014, 3:29
Now comes the fun of getting the Data Mix right!
PostPosted: October 6th, 2014, 7:41
SM2232T Simple Enough
Chips off recovery is your only way forward...
Users browsing this forum: Majestic-12 [Bot] and 81 guests
