Research ECC algo
Posted: November 1st, 2014, 9:51
Hello all forum members!
I'm experimenting with a NAND memory from flash, unsoldered and read it successfully, as a dump, understanded the layout of data and metadata,
and got the right order of blocks. The only thing I'm stopped at is checking ECC.
I supply a couple of sectors with metadata, it seems that there are 512 data bytes, followed by 6 metadata bytes, and 10 ECC bytes.
So, what I think is that it's Reed Solomon algo, probably 10bit symbol length (to cover 518 bytes) and 8 symbols ECC to total 80 bits=10 bytes.
But all my calculations resulting in different checksums, I can't get the same ECC as controller calculates. I use rslib linux library, which is a ported to userspace kernel Reed Solomon code.
I have tryed to setup the lib with init_rs(10, 0x409, 0, 1, 8) and init_rs(10, 0x409, 510, 1, 8).
The datasheet for flash controller states "4-byte ECC" being used.
Can someone help me with this as I'm almost giving up?
