HDD GURU FORUMS
http://forum.hddguru.com/
Intel 330 to 520 pcb swap
http://forum.hddguru.com/viewtopic.php?f=10&t=29965
Page 1 of 1
Author:  techrxgb [ November 18th, 2014, 2:12 ]
Post subject:  Intel 330 to 520 pcb swap
Working on an investigation whereby a drive had a hole drilled through the center of the PCB. The intel 330 series drive. I was hoping someone could confirm that the NAND chips could be unsoldered and swapped into a working drive (along with the controller) and have some likelihood of retrieval?
Author:  HaQue [ November 18th, 2014, 4:26 ]
Post subject:  Re: Intel 330 to 520 pcb swap
If the controller and nands are all ok, and the hole was drilled through pcb and discreets only, then I would say definitely should work if revisions are the same.
Soldering is going to be a little tedious, and you would need to take antistatic precautions, but payoff might be worth it.
But if you are swapping just NANDS to another cotroller+board (not 100% clear but I think this is what you are saying) then likelihood is it NOT working.
Should only be tried if all other options are exhausted
Author:  data-medics [ November 18th, 2014, 11:04 ]
Can you post a picture of the hole, so we can see what they actually drilled through.
Author:  techrxgb [ December 8th, 2014, 0:03 ]
here is a photo of the drive.
Author:  Cleanroom [ December 8th, 2014, 11:43 ]
You should be able to move the NAND chips to an identical SSD. Same PCB payout and Sam Intell 330.
I would look on ebay for one if you cannot find one. All they had to do was destroy one of those chips...
Author:  data-medics [ December 8th, 2014, 13:30 ]
I'd send that one to Luke at Recovery Force: www.recoveryforce.com
Author:  HaQue [ December 8th, 2014, 20:38 ]
Thats one lucky drill hole, unlucky for evidence/data destroyer. a lesson to people that want to destroy evidence!
http://www.phpbb.com/
