 Post subject: Seagate 1TB External HD, beeping & not recognised
PostPosted: December 18th, 2014, 5:40
Yesterday my Seagate External harddrive "fell" from my laptop on to my desk. A full 1,5 cm "drop". Suddenly the hardisk started making a tikking sound.
So I rebooted. No everytime I plug it in, it starts beeping first and then the LED start to blink. It is not recognised by the computer.
I have tried using Seatools but it does not recognise the harddisk.
Anyone has any tips on what to do? Or better yet, how to fix :-)
In this video you find a Guy with the same issue... If you guys need a better video I will make it.
https://www.youtube.com/watch?v=j5eBwbG ... e=youtu.be
Thank you very much in advanced!
Ciao
Giancarlo
 Post subject: Re: Seagate 1TB External HD, beeping & not recognised
PostPosted: December 18th, 2014, 5:51
search "head stiction"
you should send it to DR company if data is important, because DIY has its cons and pros especially for a dropped disk.
since you are in Nederland and i think Seagate Service is also available there, if your drive is under warranty you may also get replacement disk along with the data (sure you have to pay the recovery charges).
good luck
Data Recovery Pakistan
PostPosted: December 18th, 2014, 6:40
Hi MindMergepk,
Thnx! I was hoping for a magical fix ;-) I will contact Seagate to see what service they can provide me with.
Thnx for your quick reply!
Ciao
Giancarlo
PostPosted: December 18th, 2014, 11:39
Hello!
If your drive is 3.5 then i am quite sure your problem is stuck motor. In general is what happens. Now if your drive is from the smaller family , 2,5, then most probably we have a case of head stiction.
Good luck
Users browsing this forum: No registered users and 128 guests
