labtech wrote:SMART attributes?
Hmm, check the smart data, why didn't I think of that? So I checked and I don't see anything that indicates an issue. The unexpected power loss count had me wondering for a minute, but then I remembered that I have another drive in this system that doesn't always like to come up at startup so I have to do a power cycle before the OS starts loading which would be the likely cause of that count.
(4) SanDisk SDSSDH2256G
Model : SanDisk SDSSDH2256G
Firmware : X211200
Serial Number : 130504401051
Disk Size : 256.0 GB (8.4/137.4/256.0/256.0)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 500118192
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 6
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 8988 hours
Power On Count : 1484 count
Host Reads : 1067480426 GB
Host Writes : 355836969 GB
NAND Writes : 83 GB
Temperature : 28 C (82 F)
Health Status : Good (100 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM
APM Level : 00FEh [ON]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 __4 000000000000 Vendor Specific
05 100 100 __0 000000000000 Reallocated Block Count
09 253 100 __0 00000000231C Power On Hours
0C 100 100 __0 0000000005CC Power Cycle Count
A7 100 100 __0 00000000002C Max Bad Block/Die
A8 100 100 __0 00000000003B Maximum Erase Cycle
A9 100 100 __0 000000000192 Total Bad Block
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD 100 100 __0 000000000019 Average Erase Cycle
AE 100 100 __0 0000000001A5 Unexpected Power Loss Count
B8 100 100 __0 000000000000 Vendor Specific
C2 _72 _44 __0 002C0002001C Temperature
D4 100 100 __0 000000000000 SATA PHY Error
E6 100 100 __0 000000000053 Percentage Total P/E Count
E8 100 100 __0 000000000064 Spare Block Remaining
E9 100 100 __0 000000000053 Total GB Written To NAND
F1 253 253 __0 00021535A429 Total GB Written
F2 253 253 __0 00083FA0756A Total GB Read
F3 100 100 __0 000000000000 Vendor Specific
