 Post subject: DMDE getting stuck at 57 per cent
PostPosted: January 23rd, 2015, 13:58
I have a SD card here which I am trying to image (for the purposes of data rec).
I am using DMDE (latest version). However, it gets stuck at 57 per cent every time.
When I go to an image in "reverse mode" - it gets stuck at 43 per cent!
Any solutions or workarounds would be great?
 Post subject: Re: DMDE getting stuck at 57 per cent
PostPosted: January 23rd, 2015, 14:00
Not sure what the problem is exactly, but 57 + 43 = 100. Realize that there are probably few missing areas, but putting the images together as one should not be too difficult and get most of the daters.
PostPosted: January 23rd, 2015, 14:09
The other option is to use an imaging program that logs your progress so that you can jump around and flip into reverse and have a very accurate idea of how many sectors are missing. For this, I recommend GNU ddrescue.
PostPosted: January 23rd, 2015, 14:11
ok, I have 2 x .bin files (one has 57 per cent that other has 43 per cent) . How do i join these and extract data from the single file created?
PostPosted: January 23rd, 2015, 14:12
WinHex should be good right off the top of my head
Thanks Luke. I will give GNU ddrescue a try also.
PostPosted: January 23rd, 2015, 15:20
Join two images, recover data. Simple ;)
Users browsing this forum: No registered users and 123 guests
