DMDE getting stuck at 57 per cent
http://forum.hddguru.com/viewtopic.php?f=10&t=30415
Author:  ontariotech [ January 23rd, 2015, 13:58 ]
Post subject:  DMDE getting stuck at 57 per cent
I have a SD card here which I am trying to image (for the purposes of data rec).
I am using DMDE (latest version). However, it gets stuck at 57 per cent every time.
When I go to an image in "reverse mode" - it gets stuck at 43 per cent!
Any solutions or workarounds would be great?
Author:  labtech [ January 23rd, 2015, 14:00 ]
Post subject:  Re: DMDE getting stuck at 57 per cent
Not sure what the problem is exactly, but 57 + 43 = 100. Realize that there are probably few missing areas, but putting the images together as one should not be too difficult and get most of the daters.
Author:  lcoughey [ January 23rd, 2015, 14:09 ]
The other option is to use an imaging program that logs your progress so that you can jump around and flip into reverse and have a very accurate idea of how many sectors are missing. For this, I recommend GNU ddrescue.
Author:  ontariotech [ January 23rd, 2015, 14:11 ]
ok, I have 2 x .bin files (one has 57 per cent that other has 43 per cent) . How do i join these and extract data from the single file created?
Author:  labtech [ January 23rd, 2015, 14:12 ]
WinHex should be good right off the top of my head
Author:  ontariotech [ January 23rd, 2015, 14:12 ]
Thanks Luke. I will give GNU ddrescue a try also.
Author:  arvika [ January 23rd, 2015, 15:20 ]
Join two images, recover data. Simple ;)
