| Digital Photo Frame Hacking http://forum.hddguru.com/viewtopic.php?f=10&t=30461 |
Page 1 of 1 |
| Author: | hhddrec [ January 30th, 2015, 5:08 ] |
| Post subject: | Digital Photo Frame Hacking |
Hi Gurus. I have a Digital Photo Frame here. my problem is that Digital Photo Frame have 2 memories, one easily accesible but but other not easy accesible. The digital Photo Frame comes with 2 videos, 1 video is stored on not easily memory access, and i want to delete both videos. Any of you knows any tool to access to this memory and delete video? Thanks in advnaced |
| Author: | HaQue [ January 30th, 2015, 8:31 ] |
| Post subject: | Re: Digital Photo Frame Hacking |
Hi, The devkit of these are usually easy to find. Might help a LOT You haven't told what the memories are, NAND, other or much at all. Post up some more stuff and lets get to hacking! |
| Author: | hhddrec [ February 2nd, 2015, 7:23 ] |
Thanks HaQue, ill speak with customer to get 1 digital frame here. If i have news ill report here. Thaks another time. |
| Author: | HaQue [ February 2nd, 2015, 8:55 ] |
I have a couple of key ring photo frames intended for research into DR in case any customer wanted one recovered... Ok that's the story I tell when I want to hack a device .. I am guessing you are talking about the 7" ones and the like? I have some of those too.. If you get me sidetracked into having some fun with these there will be trouble! |
| Author: | fzabkar [ February 2nd, 2015, 16:28 ] |
I expect that these devices would have an embedded Linux OS. If so, then there may be a way to telnet into it via a serial port, or perhaps there is a JTAG port. Here is an example of such a project: https://sites.google.com/site/repurposelinux/df3120 |
| Author: | HaQue [ February 2nd, 2015, 20:44 ] |
I think they ported Linux to it, but the frame wasn't running Linux to start with. it isn't really clear to me in any case. This is another good resource: DPF with AppoTech AX206 http://picframe.spritesserver.nl/wiki/index.php/DPF_with_AppoTech_AX206 and our old friend Jeroen (Sprite) from spritesmods.com Use a cheap digital photoframe as a second display for your PC http://spritesmods.com/?art=picframe |
