Corsair Force GT 60
http://forum.hddguru.com/viewtopic.php?f=10&t=31067
Author:  nicolae788 [ April 28th, 2015, 15:35 ]
Post subject:  Corsair Force GT 60
Is it normal for this device to have such big discrepancies between read and write? Firmware up to date, everything installed and normal, it just doesn't want to work. Am i missing something ?
as-ssd-bench Corsair Force GT 26-Apr-15 16-22-51.png [ 29.27 KiB | Viewed 9638 times ]
Author:  HaQue [ April 28th, 2015, 20:52 ]
Post subject:  Re: Corsair Force GT 60
I have never bothered to familiarise myself with the numbers, as flash varies so much. but reading flash is always a lot quicker than writing. same with USB drives, SD Cards(these often have speeds on the labels/packaging). reading Flash is straightforward. reading and writing are different electronically, and operating system-wise in flash.
Author:  fzabkar [ April 28th, 2015, 22:12 ]
Would such a symptom be consistent with a drive that was running out of spare blocks?
Does the SMART report look OK?
Author:  nicolae788 [ April 29th, 2015, 4:00 ]
It's brand new...no problems in SMART
Author:  DRUG [ May 5th, 2015, 18:49 ]
can we have Crystaldiskinfo report ?
Author:  nicolae788 [ May 5th, 2015, 23:43 ]
Hi, thank you for your input, but the problem has been solved. The client returned this item and exchange it.
Author:  MarkGreenwood (KE) [ May 6th, 2015, 4:51 ]
Hello nicolae788
For this model of SSD,
A> You are getting quite good performance numbers. :D
B> for the lower capacity model (60GB) This is normal..
This is a generation 1 Sandforce SSD which uses Dynamic write compression, which means your write speed will vary depending on how compressible the data is that you write to it.
AS-SSD writes incompressible data for its benchmark stream and so you are looking at the worst case write scenario. (this is the performance you would get writing a large MP4 file or similar)
With compressible data (big txt files or documents) it could jump up to 150 / 200 MB/s
Unfortunately on the 60GB model you are bottle-necked by the fact that internally the drive only uses 2 write channels. the 120GB+ uses 4 and so the write performance increases exponentially.
hope this helps
Mark
Author:  nicolae788 [ May 6th, 2015, 5:15 ]
Hi Mark,
Thank you very much for your information. It surely made some light on the subject, thank you very much, you are very kind. At least now i have something to relate to the data i received in AS SSD benchmark.
Author:  fzabkar [ May 6th, 2015, 5:53 ]
The subject SSD features in the following review:
http://www.tomshardware.com/reviews/ssd ... 137-5.html
Author:  nicolae788 [ May 6th, 2015, 5:58 ]
Thank you very much @fzabkar. Interesting article.
