Crucial Password
May 24th, 2015, 23:31
The Crucial M4 series card type Msata solid disk encryption, data is not important, of course, PC3000 can bypass password access. SSD PC-3000 shows the master slave two password, how to solve. With another piece of the British SATA 512G Crucial can unlock, note: PC-3000 EXPRESS SSD version 1.0,How to unlock this password?Thanks
Master password (HEX) 48 00 00 00 44 75 6D 70 73 20 73 61 76 69 6E 67 20 77 69 74 68 20 72 65 6D 6F 76 69 6E 67 20 61
Master password (ASCII) H
User password (HEX) 6C 6C 20 74 72 61 6E 73 66 6F 72 6D 61 74 69 6F 6E 73 20 6F 6E 20 74 68 65 20 64 61 48 00 00 00
User password (ASCII) ll transformations on the daH
Re: Crucial Password
May 27th, 2015, 5:32
What is the trouble? You got the passwords, you have the PC3000.
Use PC3000 unlocking tool, you can find it in submenu "Security subsystem" somewhere in menu "Tools".
May 27th, 2015, 9:29
Thanks!PC-3000 SSD only view the password menu, there is no clear menu
May 27th, 2015, 12:17
It has. "Tools->SSD->Security->unlock", "Tools->SSD->Security->clear password".
These tools has every utility in PC3000.
May 28th, 2015, 21:34
Pc-3000 equipment has been used for many years, menu command I know, pc-3000 SSD Version 1.0 no direct scavenging password menu command, need to enter the password for decryption, but I have been successfully solved. thank you
May 29th, 2015, 4:38
Dont understand what you mean.
Can you tell us about your solution?
May 30th, 2015, 23:38
I tried to operate the level format low menu, and it was successful
