Can Firmware upgrade Delete all files on partition?
Posted: May 17th, 2015, 11:04
by hack3rcon
Hello.
I want to Upgrade my Segate HDD but can it destroy all data and partitions?
Thank you.
Re: Can Firmware upgrade Delete all files on partition?
Posted: May 17th, 2015, 15:57
by fzabkar
I recommend that people avoid the EXE versions of Seagate's updates and choose the CD ISO versions instead.
The EXE versions appear to violate the hard drive by temporarily replacing the MBR boot code with Seagate's own. I assume this is to allow Seagate's updater to gain full control of the drive during the update process. The problem with this approach is that sometimes the MBR does not revert to its original state, rendering the data inaccessible.
The CD ISO version is safe because it has its own bootable environment (FreeDOS or Linux).
Posted: May 18th, 2015, 0:46
by hack3rcon
My HDD model is "ST500DM002-1TB".
How can I obtain ISO CD ?
Posted: May 18th, 2015, 3:54
by pcimage
Why do you want to "upgrade" the firmware?
Posted: May 20th, 2015, 7:47
by hack3rcon
Sometimes Windows show me an error about HDD and ask me to Backup my data because of HDD is corrupted. I did check disk too but problem not solved.
Posted: May 20th, 2015, 10:28
by pcimage
I very much doubt it's anything to do with the firmware, more like the drive is failing
If you don't need the data, just get a new drive.
Posted: May 20th, 2015, 11:55
by Suitsof
hack3rcon wrote:My HDD model is "ST500DM002-1TB".
Posted: May 21st, 2015, 5:36
by northwind
Posted: May 24th, 2015, 15:02
by mr_spokk
northwind wrote:hack3rcon wrote:My HDD model is "ST500DM002-1TB".
Doh, It's the 002 version...it multiplies the 500Gb with x2
Posted: May 25th, 2015, 3:36
by fzabkar
hack3rcon wrote:Sometimes Windows show me an error about HDD and ask me to Backup my data because of HDD is corrupted. I did check disk too but problem not solved.
Examine the drive's SMART report with a tool such as CrystalDiskInfo:
http://crystalmark.info/software/Crysta ... dex-e.htmlLook for reallocated, pending, or uncorrectable sectors.
