 Post subject: sdcz15 8gb disassembly
PostPosted: May 31st, 2015, 6:14
Hi Member,
This SanDisk Flash drive sdcz15 8gb has problem after it get physical severe shock,
When I plug to laptopو it's become so hot and in Storage managment identefy only "64M"
I failed to disassembly it, because I didn't do this before with this kind of flash
So, I wana know how to disassembly this flash?
and I think this kind of flash have different physical content from regular flash
So, What the physical content of this flash?
Expect, the Unexpected
 Post subject: Re: sdcz15 8gb disassembly
PostPosted: May 31st, 2015, 6:28
This flash drive contains a single chip called a "Monolith" it is the Nand chip and controller chip on a single pcb and the whole lot is encased in a material same as a regular IC. Think of it like a MicroSD Card type of thing. Data recovery is sometimes possible. I am worried that yours is getting hot, as this can mean a short circuit.
These are sometimes put together with doublesided sticky tape and pushed in, so heating it(not too much) can sometimes let you pull the chip out.
PostPosted: May 31st, 2015, 6:42
Thank you HaQue for quick reply worth info,
Are you mean to heat on the flash in order to pull the chip out?
PostPosted: May 31st, 2015, 7:37
In some cases this is how they are put together, yes. Other cases, the plastic thing is snapped on, there are many different ways.
What is your plan once it is apart? There are no user serviceable parts inside.
Have a look at this collection of Monoliths to see what I mean
http://www.odzyskiwanie-danych.com.pl/monolith-database.html
PostPosted: June 1st, 2015, 1:36
thank you very much HaQue,
Users browsing this forum: No registered users and 14 guests
