Data recovery from Partially damaged Flash devices
Posted: June 22nd, 2015, 8:40
Dear All
Data Recovery from completely failed Nand flash chips /devices is extremely complex & needs thorough knowledge of electronics / programming etc. It needs hardware devices like ACE PC3000 Flash / rusolut /BVG etc,
Often we came across USB pen drives or Memory cards which are partially damaged ( show correct size , give read access but give bad sectors or some read errors). Some of the home users are not having mission critical data as well ( personal photographs ) So they are not willing to spend money as well.
Is there any low cost hardware -software solution which will identify microcontroller & image failing device as compared to plain data recovery /imaging tool . If someone know about such solution pls. let me know.
Thanks.
Thanks.
