| External HDD become RAW and I don't like to format it :( http://forum.hddguru.com/viewtopic.php?f=10&t=31516 |
Page 1 of 1 |
| Author: | hack3rcon [ July 5th, 2015, 9:43 ] | ||||
| Post subject: | External HDD become RAW and I don't like to format it :( | ||||
Hello. My External HDD become Raw and I can't open it, In Windows OS to show me "Format disk" and I want to know can I fix it without format? I attached some photos and need your advice. How about below link : http://html5.litten.com/how-to-fix-exte ... ecame-raw/ I did it and show me "Deep Search" without any partition and I did Deep search. Can it lost my data?
| Author: | falther [ July 5th, 2015, 10:51 ] |
| Post subject: | Re: External HDD become RAW and I don't like to format it :( |
knowing where "on the space" is located, one would be able to give you advice on a pro in your area .... Never the less this can be either a simple issue or something serious. Even trying to clone that drive could make it worse - a correct diagnose from a pro is the best solution ....(and no collegue, or friend of a friend or relative) Its as simple - if data is valuable for you ... get proper diagnosis, otherwise you might loose your data. whoever suggests to go on with your own DIY doesnt care for your data. +++ |
| Author: | hack3rcon [ July 5th, 2015, 14:27 ] |
Any tools or way? |
| Author: | labtech [ July 5th, 2015, 20:35 ] |
What model external is it? |
| Author: | fzabkar [ July 6th, 2015, 4:29 ] |
Can you show us a Partitions window in DMDE? http://dmde.com/ |
| Author: | labtech [ July 6th, 2015, 8:07 ] |
hack3rcon wrote: it is Silicon Power. Ok, not 100% but from I know about these, they don't have any encryption. Is this correct?
| Author: | data-medics [ July 7th, 2015, 11:59 ] |
Yes, if photorec isn't at least finding some files in RAW it's likely an encryption issue. Can you provide a picture of the original USB bridge board? That or this is a simple sector size issue. Are you directly SATA connected, or using some sort of USB adapter? I know that some adapters can't handle 4K sector drives properly. |
| Author: | hack3rcon [ July 11th, 2015, 6:45 ] |
data-medics wrote: Yes, if photorec isn't at least finding some files in RAW it's likely an encryption issue. Can you provide a picture of the original USB bridge board? That or this is a simple sector size issue. Are you directly SATA connected, or using some sort of USB adapter? I know that some adapters can't handle 4K sector drives properly. As I said, It is an External HDD. |
| Author: | Keatah [ July 13th, 2015, 17:10 ] |
Could be external sata. |
