Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bricked OCZ Vertex 2 120GB
PostPosted: July 21st, 2015, 4:44
in that case I wouldn't be using it and looking for a CP2102 based one
http://www.ebay.com/itm/Mini-CP2102-USB-2-0-to-UART-TTL-6PIN-Connector-Serial-Useful-Converter-Module-/190685792376
PostPosted: July 21st, 2015, 10:02
Thx I order it.
I try with conencted ground, then with separate PSU sSAAT power supply and still same garbage text.
I will wait for new adapter, but I think that is dead ...
PostPosted: July 27th, 2015, 8:36
before it arrive - any idea? BEcause I think that terminal output will be same garbage text ... waht about reflow Sandforce chip? Was there any problems with Sandforce BGA connection ?
Thx.
Daniel
PostPosted: February 15th, 2017, 10:23
Any luck for you SSD terminal hackers?
I am struggling with the same problem, just need to unlock the panic mode via JTAG if possible, no one seems to have done it tho...?
PostPosted: February 16th, 2017, 16:04
It is not that easy as you think. Panic mode is not a lock mode. JTAG interface, which you can see on PCB, is not for dealing with SF firmware.
Raid reconstruction solutions
Whatsapp: +971552737521
Users browsing this forum: Google [Bot] and 4 guests
