USB drive toasted by Dell workstation - can it be recovered?
Posted: July 18th, 2015, 21:31
I am a new member of HDD Guru Forums, but I have enjoyed the articles and posts on and off for awhile. I appreciate the quality of this forum and its membership. Storage media and data recovery have been an interest of mine for years, during which time I've had a small number of DIY DR successes. No failures yet.
I have a PNY 128GB USB stick that failed immediately when it was connected to a high end, expensive Dell workstation running Windows 7. I connected a sacrificial USB stick to the same port and it developed the same problem. After booting a Linux O/S, I discovered over-current conditions in the system boot log for that USB port. I have no record of the drive's contents except that it contains 80+ GB of work-related files. Some of the data may be proprietary company information. Again, no clear record of that.
I do not see a fuse on the circuit board, nor do I see any physical defects under magnification. The controller is an Alcor AU6998SN with an integrated fuse and oscillator. I believe it may be damaged.
There are two 64GB ball grid array (BGA) NAND chips. I assume these are 8-bit. I'm not able to find information about these chips since they do not bear comprehensive markings. There are no markings underneath the paper sticker. I can get the chips off the board and onto a pogo pin fixture, but I assume that the chip pinouts are not standardized across the industry.
It's likely that successful DR will require chip-off procedures. I am familiar with the work of Bjoern Kerler, Joshua Wise and others. Countering that, I understand the excellent points made by Dmitry in his DIY post here http://forum.hddguru.com/viewtopic.php?f=16&t=12671 This should be a sticky. I realize there are complicating factors that differ with each job and the work should be left to DR professionals, but I do not have budget or clearance to farm the work out at this time.
A few questions for anyone who can spare the time to answer:
Thank you for the interesting (sometimes fascinating) reading provided by this professional forum.
Kind regards,
wibit
- Does my analysis seem to be reasonable up to this point?
I have another controller chip (identical) but I assume that a controller transplant may be useless or even unwise, correct?
Is it possible to find data sheets, or even just pinout information, for the NAND chips used in this device?
This seems like a straightforward recovery, since the chips are intact. What might a commercial data recovery center charge for this?
Where would I find a competent DR provider in the United States, Canada, or Europe?
Are they better (training, experience, results) in some countries than others?
Why do DR agencies think it is their right to retain customer data? This is something I do not see enough discussion on.
Kind regards,
wibit
