SSD bricked after secure erase?
Posted: August 2nd, 2015, 6:49
Hello everyone (sorry for my english).
Yesterday i decided to erase my KingstonSSDNow v300.
I found this link: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
I was using Ubuntu 14.04.1 botted on Sony VAIO sve 1511g1esi.
Steps i made:
1.first, i checked if disk is locked/frozen. Everything was ok so i go to the next step,
2.
3.
And finally i stuck here, because this command returned:
At the moment, commands with --security-* don't work, everytime i get I/O errors.
I don't need data from ssd because i made backup.
Information from hdparm -I /dev/sda:
Any suggestions?
Steps i made:
2.
- Code:
hdparm --user-master u --security-set-pass Eins /dev/sda
3.
- Code:
time hdparm --user-master u --security-erase Eins /dev/sda
- Code:
/dev/sda:
Issuing SECURITY_ERASE command, password="Eins", user=user
ERASE_PREPARE: Input/output error
- Code:
/dev/sda:
ATA device, with non-removable media
Model Number: KINGSTON SV300S37A120G
Serial Number: 50026B774608D51F
Firmware Revision: 527ABBF0
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Used: unknown (minor revision code 0x0110)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 234441648
LBA48 user addressable sectors: 234441648
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 114473 MBytes
device size with M = 1000*1000: 120034 MBytes (120 GB)
cache/buffer size = unknown
Nominal Media Rotation Rate: Solid State Device
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, with device specific minimum
R/W multiple sector transfer: Max = 16 Current = 1
Advanced power management level: 254
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
* Security Mode feature set
* Power Management feature set
* Write cache
Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
* 48-bit Address feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
Write-Read-Verify feature set
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
unknown 119[6]
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Gen3 signaling speed (6.0Gb/s)
* Native Command Queueing (NCQ)
* Phy event counters
* NCQ priority information
* READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
* DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Write Same (AC2)
* SCT Data Tables (AC5)
* reserved 69[3]
* DOWNLOAD MICROCODE DMA command
* SET MAX SETPASSWORD/UNLOCK DMA commands
* WRITE BUFFER DMA command
* READ BUFFER DMA command
* Data Set Management TRIM supported (limit 1 block)
Security:
Master password revision code = 65534
supported
enabled
locked
not frozen
expired: security count
supported: enhanced erase
Security level high
2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50026b774608d51f
NAA : 5
IEEE OUI : 0026b7
Unique ID : 74608d51f
Checksum: correct
Any suggestions?
