 Post subject: Recovering Files From Failing SSD
PostPosted: August 2nd, 2015, 20:25
I have a 128GB SanDisk SSD (SDSSDP-128G-G25) that is a little over two years old. The drive appears to have failed as I can't boot off it. I have tried unsuccessfully to recover files from it.
I booted off a BootMed Live CD and executed dd_rescue to write an image of the disk to another drive. I let it run for several hours but the image file was empty so I broke out of it.
Below is the command I entered and some of the output displayed to the screen before I broke out of it.
sudo dd_rescue /dev/sda /media/Elements/SanDisk128GB.dd
dd_rescue: (warning): /dev/sda (47928108.0k): Input/output error!
dd_rescue: (info): ipos: 47928108.0k, opos: 47928108.0k, xferd: 47928108.0k
* errs:95856214, errxfer: 47928108.0k, succxfer: 0.0k
+curr.rate: 5102kB/s, avg.rate: 706kB/s, avg.load: 9.6%
* errs:95856215, errxfer: 47928108.0k, succxfer: 0.0k
* errs:95856216, errxfer: 47928108.0k, succxfer: 0.0k
+curr.rate: 4673kB/s, avg.rate: 706kB/s, avg.load: 9.6%
^Cdd_rescue: (fatal): Caught signal 2 "Interrupt". Exiting!
Summary for /dev/sda -> /media/Elements/SanDisk128GB.dd:
errs:95856217, errxfer: 47928108.0k, succxfer: 0.0k
+curr.rate: 31kB/s, avg.rate: 706kB/s, avg.load: 9.6%
I tried the BootMed TestDisk utility but it received a read error when trying to read the partition table:
TestDisk 6.11, Data Recovery Utility, April 2009
Christophe GRENIER <grenier@cgsecurity.org>http://www.cgsecurity.org
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63
Current partition structure:
Partition Start End Size in sectors
Partition: Read error
*=Primary bootable P=Primary L=Logical E=Extended D=Deleted
I am not sure what to try next. I would appreciate it if someone could point me in the right direction. Thanks.
Dave
