| Recovering Files From Failing SSD http://forum.hddguru.com/viewtopic.php?f=10&t=31702 |
Page 1 of 1 |
| Author: | DMH [ August 2nd, 2015, 20:25 ] |
| Post subject: | Recovering Files From Failing SSD |
Hi, I have a 128GB SanDisk SSD (SDSSDP-128G-G25) that is a little over two years old. The drive appears to have failed as I can't boot off it. I have tried unsuccessfully to recover files from it. I booted off a BootMed Live CD and executed dd_rescue to write an image of the disk to another drive. I let it run for several hours but the image file was empty so I broke out of it. Below is the command I entered and some of the output displayed to the screen before I broke out of it. sudo dd_rescue /dev/sda /media/Elements/SanDisk128GB.dd dd_rescue: (warning): /dev/sda (47928108.0k): Input/output error! dd_rescue: (info): ipos: 47928108.0k, opos: 47928108.0k, xferd: 47928108.0k * errs:95856214, errxfer: 47928108.0k, succxfer: 0.0k +curr.rate: 5102kB/s, avg.rate: 706kB/s, avg.load: 9.6% dd_rescue: (warning): /dev/sda (47928108.0k): Input/output error! dd_rescue: (info): ipos: 47928108.0k, opos: 47928108.0k, xferd: 47928108.0k * errs:95856215, errxfer: 47928108.0k, succxfer: 0.0k +curr.rate: 5102kB/s, avg.rate: 706kB/s, avg.load: 9.6% dd_rescue: (warning): /dev/sda (47928108.0k): Input/output error! dd_rescue: (info): ipos: 47928108.0k, opos: 47928108.0k, xferd: 47928108.0k * errs:95856216, errxfer: 47928108.0k, succxfer: 0.0k +curr.rate: 4673kB/s, avg.rate: 706kB/s, avg.load: 9.6% dd_rescue: (warning): /dev/sda (47928108.0k): Input/output error! ^Cdd_rescue: (fatal): Caught signal 2 "Interrupt". Exiting! Summary for /dev/sda -> /media/Elements/SanDisk128GB.dd: dd_rescue: (info): ipos: 47928108.0k, opos: 47928108.0k, xferd: 47928108.0k errs:95856217, errxfer: 47928108.0k, succxfer: 0.0k +curr.rate: 31kB/s, avg.rate: 706kB/s, avg.load: 9.6% I tried the BootMed TestDisk utility but it received a read error when trying to read the partition table: TestDisk 6.11, Data Recovery Utility, April 2009 Christophe GRENIER <grenier@cgsecurity.org>http://www.cgsecurity.org Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63 Current partition structure: Partition Start End Size in sectors Partition: Read error *=Primary bootable P=Primary L=Logical E=Extended D=Deleted I am not sure what to try next. I would appreciate it if someone could point me in the right direction. Thanks. Dave |
