 Post subject: Kingston DTM30 bricked after UPtool
PostPosted: August 11th, 2015, 10:18
Hello everybody , yesterday a friend of mine give to me his usb thumb because he saw that in windows the partition was 0 GB.
I tried to generate a new partition and reformat it without success. I used some partition managers but nothing.
Today I used Chip Genius to find what microcontroller is inside and what kind of flash to search proper MP to refresh it.
I found that the microcontroller is Phison 2251-07 and the flash TH58NVG9TDK(4CE)(eD3.8K)-64GB[4/1]
I use the UPtool version 2092 and after detecting the device I started the procedure all good for now after a few mintes it give an error and the process stopped. Before remove of the drive and reinsert I saw that is not detectable anymore.
It is a posibility to revive it from that point or is a "brick" ?
Below is the log of UPtool :
[ 2015-08-11 16:41:46 ]
OS Version: Win XP
MP Version: 2.092 (2014.10.24)
PC Name : []
DUT Slot: 0
Driver : E
IC Type : 67-1
ISP Type: 1
F-Slot : 1
0:00.0 -------------------------------------
0:00.0 New Flow Initial ... 2092
0:00.0 + INQ:........ 2307 SORTER V1.01.00........
0:01.1 + ISP Version : OS07 Ver 3.08 (2014.10.21-1)
0:01.1 + Flash Unit Index = 77 / (231) / 649
0:01.1 - ID: 98-3A-A8-92-76-50 x 4
0:01.1 - Mask: FF-FF-EF-FF-FF-8F
0:01.1 - Flash Parameters : 19nm,x8,8344,86,16, HW.ECC=60,844
0:01.1 Flash Notes: Toshiba 1xnm eD3 (2014.03.17)
0:01.1 + New CE Mode_3=00, CEMask=0F
0:01.3 + ECC setting : 60, 60, 36
0:01.3 * Model=67-1-1
0:01.3 - UP307,,TH58NVG9TDK(4CE)(eD3.8K)-64GB[4/1]
0:01.3 + Total effective blocks = 4 x 1 x 8344 = 33376
0:01.3 + Bad Column Init ...
0:01.3 >>> Flash Not Support OBC <<<
0:01.3 -------------------------------------
0:01.3 Test & Scan Stage ... 1 FSlot mode
0:01.3 [ Low Level Format + TestMode=0 ]
0:01.3 >> SmartEcc=1, Ecc=4
0:01.3 >> Mode=3, Optimize=1, SizeMode=0
0:01.3 >> Max ECC = D1(45), D3(20,50,D1+D3=50)
0:01.3 + Smart Test ... 0000-0000
0:01.3 + INQ:........ 2307 SORTER V1.01.00........
0:01.3 + ISP Version : OS07 Ver 3.08 (2014.10.21-1)
0:01.3 + GPIO = 00,73,FF,0C
0:01.3 + New CE Mode_3=00, CEMask=0F
0:01.5 + ECC setting : 60, 60, 36
0:01.5 + Set Retry Table (A19 eD3 D1).
0:01.5 + CE=4, Page Layout Mode = 0, MaxWL=86
0:01.5 + Total effective blocks = 4 x 1 x 8344 = 33376
0:01.5 +-----------------------------------------------------+
0:01.5 + Double Check Block Scan ... 0-2(CCCC), Marker=C2
0:02.6 + 0-0-0000: ................................................................
0:03.8 + 0-0-0040: ................................................................
0:04.9 + 0-0-0080: ................................................................
0:06.0 + 0-0-00C0: ..............................................UU................
0:07.1 + 0-0-0100: ................................................................
0:08.3 + 0-0-0140: ................................................................
0:09.4 + 0-0-0180: ................................................................
0:10.5 + 0-0-01C0: ................................................................
0:11.6 + 0-0-0200: ................................................................
0:12.8 + 0-0-0240: ................................................................
0:13.9 + 0-0-0280: ..........................UU....................................
0:15.0 + 0-0-02C0: ................................................................
0:16.1 + 0-0-0300: ................................................................
0:17.2 + 0-0-0340: ................................................................
0:18.3 + 0-0-0380: ................................................................
0:19.4 + 0-0-03C0: ................................................................
0:20.5 + 0-0-0400: ................................................................
0:21.6 + 0-0-0440: ................................................................
0:22.8 + 0-0-0480: ................................................................
0:23.9 + 0-0-04C0: ................................................................
0:25.0 + 0-0-0500: ................................................................
0:26.1 + 0-0-0540: ................................................................
0:27.2 + 0-0-0580: ................................................................
0:28.3 + 0-0-05C0: ................................................................
0:29.4 + 0-0-0600: ................................................................
0:30.5 + 0-0-0640: ............................UU..................................
0:31.6 + 0-0-0680: ................................................................
0:32.7 + 0-0-06C0: ................................................................
0:33.8 + 0-0-0700: ................................................................
0:34.9 + 0-0-0740: ................................................................
0:36.1 + 0-0-0780: ................................................................
0:37.2 + 0-0-07C0: ................................................................
0:38.3 + 0-0-0800: ..................................UU............................
0:39.4 + 0-0-0840: ................................................................
0:40.5 + 0-0-0880: ................................................................
0:41.7 + 0-0-08C0: ................................................................
0:42.8 + 0-0-0900: ................................................................
0:43.9 + 0-0-0940: ................................................................
0:45.0 + 0-0-0980: ................................................................
0:46.2 + 0-0-09C0: ................................................................
0:47.3 + 0-0-0A00: ................................................................
0:48.5 + 0-0-0A40: ............................UU..................................
0:49.6 + 0-0-0A80: ................................................................
0:51.1 + 0-0-0AC0: ................................................................
0:52.3 + 0-0-0B00: ................................................................
0:53.3 + 0-0-0B40: ................................................UU..............
0:54.5 + 0-0-0B80: ................................................................
0:55.6 + 0-0-0BC0: ................................................................
0:56.7 + 0-0-0C00: ................................................................
0:57.8 + 0-0-0C40: ................................................................
0:58.9 + 0-0-0C80: ................................................................
1:00.0 + 0-0-0CC0: ................................................................
1:01.1 + 0-0-0D00: ........UU......................................................
1:02.3 + 0-0-0D40: ................................................................
1:03.4 + 0-0-0D80: ................................................................
1:04.5 + 0-0-0DC0: ................................................................
1:05.7 + 0-0-0E00: ................................................................
1:06.9 + 0-0-0E40: ................................................................
1:08.0 + 0-0-0E80: ................................................................
1:09.1 + 0-0-0EC0: ................................................................
1:10.2 + 0-0-0F00: ................................................................
1:11.4 + 0-0-0F40: ................................................................
1:12.6 + 0-0-0F80: ................................................................
1:13.7 + 0-0-0FC0: ................................................................
1:14.8 + 0-0-1000: ................................................................
1:15.9 + 0-0-1040: ................................................................
1:17.1 + 0-0-1080: ................................................................
1:18.2 + 0-0-10C0: ................................................................
1:19.3 + 0-0-1100: ................................................................
1:20.4 + 0-0-1140: ................................................................
1:21.5 + 0-0-1180: ................................................................
1:22.6 + 0-0-11C0: ................................................................
1:23.7 + 0-0-1200: ................................................................
1:24.8 + 0-0-1240: ................................................................
1:25.9 + 0-0-1280: ................................................................
1:27.0 + 0-0-12C0: ................................................................
1:28.2 + 0-0-1300: ................................................................
1:29.3 + 0-0-1340: ................................................................
1:30.4 + 0-0-1380: ................................................................
1:31.5 + 0-0-13C0: ................................................................
1:32.6 + 0-0-1400: ................................................................
1:33.7 + 0-0-1440: ................................................................
1:34.9 + 0-0-1480: ................................................................
1:36.0 + 0-0-14C0: ................................................................
1:37.1 + 0-0-1500: ........................UU..UU..................................
1:38.2 + 0-0-1540: ................................................................
1:39.3 + 0-0-1580: ................................................................
1:40.4 + 0-0-15C0: ................................................................
1:41.5 + 0-0-1600: ................................................................
1:42.7 + 0-0-1640: ................................................................
1:43.8 + 0-0-1680: ................................................................
1:44.9 + 0-0-16C0: ................................................................
1:46.0 + 0-0-1700: ..........................................UU....................
1:47.1 + 0-0-1740: ................................................................
1:48.1 + 0-0-1780: ................................UU..UU..........................
1:49.3 + 0-0-17C0: ................................................................
1:50.4 + 0-0-1800: ................................................................
1:51.5 + 0-0-1840: ................................................................
1:52.6 + 0-0-1880: ................................................................
1:53.7 + 0-0-18C0: ................................................................
1:54.8 + 0-0-1900: ................................................................
1:55.9 + 0-0-1940: ................................................................
1:57.0 + 0-0-1980: ................................................................
1:58.1 + 0-0-19C0: ................................................................
1:59.2 + 0-0-1A00: ................................................................
2:00.3 + 0-0-1A40: ................................................................
2:01.4 + 0-0-1A80: ................................................................
2:02.5 + 0-0-1AC0: ................................................................
2:03.7 + 0-0-1B00: ................................................................
2:04.7 + 0-0-1B40: ..................................................UU............
2:05.8 + 0-0-1B80: ................................................................
2:07.0 + 0-0-1BC0: ................................................................
2:08.0 + 0-0-1C00: ......................UU........................................
2:09.2 + 0-0-1C40: ................................................................
2:10.3 + 0-0-1C80: ................................................................
2:11.4 + 0-0-1CC0: ................................................................
2:12.5 + 0-0-1D00: ................................................................
2:13.6 + 0-0-1D40: ................................................................
2:14.8 + 0-0-1D80: ................................................................
2:15.9 + 0-0-1DC0: ................................................................
2:17.1 + 0-0-1E00: ................................................................
2:18.2 + 0-0-1E40: ................................................................
2:19.3 + 0-0-1E80: ................................................................
2:20.4 + 0-0-1EC0: ................................................................
2:21.5 + 0-0-1F00: ................................................................
2:22.7 + 0-0-1F40: ................................................................
2:23.8 + 0-0-1F80: ................................................................
2:24.9 + 0-0-1FC0: ................................................................
2:26.1 + 0-0-2000: ................................................................
2:27.2 + 0-0-2040: ..................UU............................................
2:27.7 + 0-0-2080: ........................
2:28.8 + 1-0-0000: ................................................................
2:29.9 + 1-0-0040: ................................................................
2:31.0 + 1-0-0080: ................................................................
2:32.2 + 1-0-00C0: ................................................................
2:33.3 + 1-0-0100: ................................................................
2:34.4 + 1-0-0140: ................................................................
2:35.6 + 1-0-0180: ................................................................
2:36.7 + 1-0-01C0: ................................................................
2:37.8 + 1-0-0200: ......................................UU........................
2:38.9 + 1-0-0240: ................................................................
2:40.1 + 1-0-0280: ................................................................
2:41.2 + 1-0-02C0: ................................................................
2:42.4 + 1-0-0300: ................................................................
2:43.5 + 1-0-0340: ................................................................
2:44.7 + 1-0-0380: ................................................................
2:45.8 + 1-0-03C0: ................................................................
2:46.9 + 1-0-0400: ................................................................
2:48.0 + 1-0-0440: ..........................................................UU....
2:49.1 + 1-0-0480: ................................................................
2:50.3 + 1-0-04C0: ................................................................
2:51.4 + 1-0-0500: ................................................................
2:52.5 + 1-0-0540: ................................................................
2:53.6 + 1-0-0580: ................................................................
2:54.8 + 1-0-05C0: ................................................................
2:55.9 + 1-0-0600: ................................................................
2:57.0 + 1-0-0640: ................................................................
2:58.2 + 1-0-0680: ................................................................
2:59.3 + 1-0-06C0: ................................................................
3:00.5 + 1-0-0700: ................................................................
3:01.6 + 1-0-0740: ..........................................UU....................
3:02.7 + 1-0-0780: ................................................................
3:03.8 + 1-0-07C0: ................................................................
3:05.0 + 1-0-0800: ................................................................
3:06.1 + 1-0-0840: ............UU..................................................
3:07.2 + 1-0-0880: ................................................................
3:08.3 + 1-0-08C0: ................................................................
3:09.4 + 1-0-0900: ................................................................
3:10.6 + 1-0-0940: ................................................................
3:11.7 + 1-0-0980: ................................................................
3:12.8 + 1-0-09C0: ................................................................
3:14.0 + 1-0-0A00: ................................................................
3:15.1 + 1-0-0A40: ................................................................
3:16.2 + 1-0-0A80: ................................................................
3:17.3 + 1-0-0AC0: ................................................................
3:18.5 + 1-0-0B00: ................................................................
3:19.6 + 1-0-0B40: ................................................................
3:20.8 + 1-0-0B80: ................................................................
3:21.8 + 1-0-0BC0: ..................................UU............................
3:23.0 + 1-0-0C00: ................................................................
3:24.1 + 1-0-0C40: ................................................................
3:25.2 + 1-0-0C80: ................................................................
3:26.4 + 1-0-0CC0: ................................................................
3:27.5 + 1-0-0D00: ......................................................UU........
3:28.6 + 1-0-0D40: ................................................................
3:29.7 + 1-0-0D80: ................................................................
3:30.8 + 1-0-0DC0: ................................................................
3:32.0 + 1-0-0E00: ................................................................
3:33.1 + 1-0-0E40: ................................................................
3:34.1 + 1-0-0E80: ..................................................UU..UU..UU..UU
3:35.0 + 1-0-0EC0: ..UU..UU..UU..UU..UU..UU......................UU................
3:36.2 + 1-0-0F00: ................................................................
3:37.4 + 1-0-0F40: ................................................................
3:38.5 + 1-0-0F80: ................................................................
3:39.6 + 1-0-0FC0: ......UU........................................................
3:40.7 + 1-0-1000: ................................................................
3:41.9 + 1-0-1040: ................................................................
3:43.0 + 1-0-1080: ................................................................
3:44.1 + 1-0-10C0: ................................................................
3:45.2 + 1-0-1100: ................................................................
3:46.3 + 1-0-1140: ..............................................................UU
3:47.4 + 1-0-1180: ................................................................
3:48.5 + 1-0-11C0: ................................................................
3:49.6 + 1-0-1200: ................................................................
3:50.8 + 1-0-1240: ................................................................
3:51.9 + 1-0-1280: ................................................................
3:53.0 + 1-0-12C0: ................................................................
3:54.2 + 1-0-1300: ................................................................
3:55.3 + 1-0-1340: ................................................................
3:56.4 + 1-0-1380: ................................................................
3:57.5 + 1-0-13C0: ................................................................
3:58.7 + 1-0-1400: ................................................................
3:59.8 + 1-0-1440: ................................................................
4:00.9 + 1-0-1480: ................................................................
4:02.0 + 1-0-14C0: ................................................................
4:03.1 + 1-0-1500: ................................................................
4:04.3 + 1-0-1540: ................................................................
4:05.4 + 1-0-1580: ................................................................
4:06.5 + 1-0-15C0: ................................................................
4:07.6 + 1-0-1600: ................................................................
4:08.7 + 1-0-1640: ................................................................
4:09.9 + 1-0-1680: ................................................................
4:11.0 + 1-0-16C0: ................................................................
4:12.1 + 1-0-1700: ................................................................
4:13.2 + 1-0-1740: ................................................................
4:14.3 + 1-0-1780: ................................................................
4:15.5 + 1-0-17C0: ................................................................
4:16.6 + 1-0-1800: ................................................................
4:17.8 + 1-0-1840: ................................................................
4:18.8 + 1-0-1880: ................................................UU..............
4:20.0 + 1-0-18C0: ................................................................
4:21.1 + 1-0-1900: ................................................................
4:22.2 + 1-0-1940: ................................................................
4:23.4 + 1-0-1980: ................................................................
4:25.6 + 1-0-19C0: ................................................................
4:26.7 + 1-0-1A00: ................................................................
4:27.8 + 1-0-1A40: ................................................................
4:29.0 + 1-0-1A80: ................................................................
4:30.1 + 1-0-1AC0: ................................................................
4:31.2 + 1-0-1B00: ................................................................
4:32.3 + 1-0-1B40: ................................................................
4:33.4 + 1-0-1B80: ................................................................
4:34.5 + 1-0-1BC0: ................................................................
4:35.7 + 1-0-1C00: ................................................................
4:36.8 + 1-0-1C40: ................................................................
4:37.9 + 1-0-1C80: ................................................................
4:39.0 + 1-0-1CC0: ................................................................
4:40.1 + 1-0-1D00: ................................................................
4:41.3 + 1-0-1D40: ................................................................
4:42.4 + 1-0-1D80: ................................................................
4:43.5 + 1-0-1DC0: ................................................................
4:44.6 + 1-0-1E00: ................................................................
4:45.7 + 1-0-1E40: ................................................................
4:46.8 + 1-0-1E80: ................................................................
4:48.0 + 1-0-1EC0: ................................................................
4:49.1 + 1-0-1F00: ................................................................
4:50.3 + 1-0-1F40: ................................................................
4:51.4 + 1-0-1F80: ................................................................
4:52.6 + 1-0-1FC0: ................................................................
4:53.8 + 1-0-2000: ................................................................
4:55.0 + 1-0-2040: ................................................................
4:55.5 + 1-0-2080: ........................
4:56.7 + 2-0-0000: ................................................................
4:57.8 + 2-0-0040: ................................................................
4:59.0 + 2-0-0080: ................................................................
5:00.2 + 2-0-00C0: ................................................................
5:01.3 + 2-0-0100: ................................................................
5:02.5 + 2-0-0140: ................................................................
5:03.6 + 2-0-0180: ................................................................
5:04.7 + 2-0-01C0: ................................................................
5:05.8 + 2-0-0200: ................................................................
5:07.0 + 2-0-0240: ................................................................
5:08.1 + 2-0-0280: ................................................................
5:09.2 + 2-0-02C0: ................................................................
5:10.3 + 2-0-0300: ................................................................
5:11.4 + 2-0-0340: ................................................................
5:12.5 + 2-0-0380: ................................................................
5:13.6 + 2-0-03C0: ................................................................
5:14.8 + 2-0-0400: ................................................................
5:15.9 + 2-0-0440: ................................................................
5:17.0 + 2-0-0480: ................................................................
5:18.1 + 2-0-04C0: ................................................................
5:19.3 + 2-0-0500: ................................................................
5:20.4 + 2-0-0540: ................................................................
5:21.5 + 2-0-0580: ................................................................
5:22.6 + 2-0-05C0: ................................................................
5:23.7 + 2-0-0600: ................................................................
5:24.8 - FW Spare = 16,57
5:24.8 + New ISP to Save IB Table.
5:24.8 + Free PC RAM: 473/2046 MB
5:24.8 [RESULT] ErrorCode : 0099
5:24.8 + Static Summary: B=0 ,P=0 ,S=0 ,Others=0 ,D1B=0 ,D1P=0 ,D1S=0 ,D1Others=0 ,
[ 2015-08-11 16:47:11 ]
[ UPTool takes 00:05:25 ]
The usb thumb is monolithic type
Thank you for reading and help.
Users browsing this forum: No registered users and 43 guests
