Recovered files contain only zeros / Pics and Vids deleted
Posted: August 21st, 2015, 5:47
Dear community,
I accidentally deleted my folder containing all pics and videos (125 GB). Since it is that big it was not moved to the recycle bin but permanently deleted instead.
Over the past 2 days I used pretty much every software that is available to recover the file but I haven't been successful to recover not even one of the files.
Recuva restored all files with original file names, size and date but none of the files could be opened (I restored the file to an external HDD)
GetDataBack for NTFS finds the MFT entry would every file including clusters and sectors information but when you preview the file it contains only zeros.
I also did an experiment and copied a picture to another partition of the SSD and deleted it by moving it into the recycle bin and afterwards permanently. When it was in the recycle bin it could still be restored by GetDataBack for NTFS but as soon as you delete it from the recycle bin it only contains zeros.
I first thought that Windows 8 might have learned a secure delete by overwriting everything with zeros when you delete permanently but the deletion process of 125 GB was completed way to fast to actually overwrite the space.
I really hope that someone in this community can help me since I'm running out of ideas and panic hits me that I will never see these pictures again.
Thank you so much!
Niklas
Thank you so much!
Niklas
