i need firmware to my usb (Kingston DT microDuo) 16 GB
Posted: September 6th, 2015, 1:29
hi
i have this usb
it is working fine but only on my laptop if i but it to my phone i cant use it
so foundUPTool_Ver2092(Release)-HH_20141229 and it is see my flash all was working fine but in the end i have this error ErrorCode : 0078
[D] UP23N,,TH58TEG7TCK (2CE) (eD3.8K)-16GB[2/1] 00:04:15 ### Err:0078 ### 2-D3-2P [00.-10-]
this is the full log
[ 2015-09-06 05:35:00 ]
OS Version: Win 7
MP Version: 2.092 (2014.10.24)
PC Name : []
DUT Slot: 0
Driver : D
IC Type : 1E-0
ISP Type: 1
F-Slot : 1
0:00.0 -------------------------------------
0:00.0 New Flow Initial ... 2092
0:00.0 + INQ:........ 2268 SORTER V1.01.00PMAP1234
0:01.0 + ISP Version : OS68 Ver 1.08k (2014.10.21-1)
0:01.0 + Flash Unit Index = 47 / (140) / 649
0:01.0 - ID: 98-DE-98-92-72-50 x 2
0:01.0 - Mask: FF-FF-EF-FF-FF-8F
0:01.1 - Flash Parameters : 19nm,x8,4184,86,16, HW.ECC=60,844
0:01.1 Flash Notes: Toshiba 1xnm eD3 (2013.10.14)
0:01.1 + New CE Mode_3=06, CEMask=03
0:01.3 + ECC setting : 60, 60, 36
0:01.3 * Model=1E-0-1
0:01.3 - UP23N,,TH58TEG7TCK(2CE)(eD3.8K)-16GB[2/1]
0:01.3 + Total effective blocks = 2 x 1 x 4184 = 8368
0:01.3 + Bad Column Init ...
0:01.3 >>> Flash Not Support OBC > Mode=3, Optimize=1, SizeMode=0
0:01.3 >> Max ECC = D1(45), D3(20,50,D1+D3=50)
0:01.3 -------------------------------------
0:01.3 + Smart Test ... 0000-0000
0:01.3 + INQ:........ 2268 SORTER V1.01.00PMAP1234
0:01.3 + ISP Version : OS68 Ver 1.08k (2014.10.21-1)
0:01.3 + GPIO = FF,06,FF,FF
0:01.3 + New CE Mode_3=06, CEMask=03
0:01.5 + ECC setting : 60, 60, 36
0:01.5 + Set Retry Table (A19 eD3 D1).
0:01.5 + CE=2, Page Layout Mode = 0, MaxWL=86
0:01.5 + Total effective blocks = 2 x 1 x 4184 = 8368
0:01.5 +-----------------------------------------------------+
0:01.5 + Double Check Block Scan ... 0-2(CCCC), Marker=C2
4:07.6 - Total 8320 Good D1 Blocks
4:07.6 [D3 DefectBlock] .. C4
4:07.6 + CE-0:0146,0147,0148,0149,042E,042F,0584,0585,082C,082D,083A,083B,08B6,08B7,0A04,0A05,
4:07.6 1056,1057,
4:07.6 + CE-1:0118,0119,0202,0203,03B2,03B3,03B4,03B5,0518,0519,064E,064F,07AC,07AD,0962,0963,
4:07.6 0DFE,0DFF,0E00,0E01,0F28,0F29,0FD0,0FD1,0FE6,0FE7,0FE8,0FE9,1056,1057,
4:07.6 - Total 48 Bad D3 Blocks
4:07.6 O.PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
4:07.6 O.SA[]=OOOOOOOO
4:07.6 + Calculate User BIN ... CE(0-1)
4:07.6 - Bad Wl = 0,0
4:07.8 - FW Spare = 16,57
4:07.8 - Calculate capacity D3 : WL(Good/Bad) = 86 / 0
4:07.8 + Calculate Disk Size (D3 Only):
4:08.0 - Calculate D3 Good Block (E=4160,O=4160,F=8320)
4:08.0 + Calculate Disk Size (D1 Only):
4:08.0 - Calculate D1 Good Block (E=4160,O=4160,F=8320)
4:08.0 - Size= 16761 =(8320-4) x (86) x (8-0) x 3 / 1024
4:08.0 Physical Size=16761 (MB), Selected Size=16761 (MB)
4:08.1 + Setup Parameters for IB-Table ... Slot-0
4:08.1 PA[]=OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
4:08.1 SA[]=OOOOOOOO
4:08.1 - F0: Total Sector=8, Pages for IB=1
4:08.1 - EvenZonePage[]=0,1,2,3, OddZonePage[]=0,1,2,3
4:08.1 + 40(00) / OBC:40(00)
4:08.1 + Not found OLD IB, Save a newer
4:08.1 -------------------------------------------
4:08.2 + Install IB-Table ... Page=8 K, Skip=0000, TM=33, MBC=0, EM=C3
4:08.2 - SecMapping :0(0),1(1),2(2),3(3),4(4),5(5),6(6),7(7),
4:08.2 - Toshiba 19/24nm block pair (0000-0001)
4:08.2 - Good/Plane=2091,2091,
4:08.6 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:08.6 *** Warning: Create IB Table fail(CE:0 Block:0 Page:0) failed
4:08.6 - Good/Plane=2091,2091,
4:08.8 *** Warning: Create IB Table fail(CE:0 Block:0 Page:0) failed
4:08.8 - Toshiba 19/24nm block pair (0001-0000)
4:08.8 - Good/Plane=2091,2091,
4:09.1 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:09.1 *** Warning: Create IB Table fail(CE:0 Block:1 Page:0) failed
4:09.2 - Good/Plane=2091,2091,
4:09.3 *** Warning: Create IB Table fail(CE:0 Block:1 Page:0) failed
4:09.3 - Toshiba 19/24nm block pair (0002-0003)
4:09.3 - Good/Plane=2090,2090,
4:09.7 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:09.7 *** Warning: Create IB Table fail(CE:0 Block:2 Page:0) failed
4:09.7 - Good/Plane=2090,2090,
4:09.9 *** Warning: Create IB Table fail(CE:0 Block:2 Page:0) failed
4:09.9 - Toshiba 19/24nm block pair (0003-0002)
4:09.9 - Good/Plane=2090,2090,
4:10.2 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:10.2 *** Warning: Create IB Table fail(CE:0 Block:3 Page:0) failed
4:10.2 - Good/Plane=2090,2090,
4:10.4 *** Warning: Create IB Table fail(CE:0 Block:3 Page:0) failed
4:10.4 - Toshiba 19/24nm block pair (0004-0005)
4:10.4 - Good/Plane=2089,2089,
4:10.8 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:10.8 *** Warning: Create IB Table fail(CE:0 Block:4 Page:0) failed
4:10.8 - Good/Plane=2089,2089,
4:10.9 *** Warning: Create IB Table fail(CE:0 Block:4 Page:0) failed
4:11.0 ### Err: IB-Table create failed (CE=0,DIE=0).
4:11.0 - Toshiba 19/24nm block pair (0000-0001)
4:11.0 - Good/Plane=2091,2091,
4:11.3 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:11.3 *** Warning: Create IB Table fail(CE:1 Block:0 Page:0) failed
4:11.3 - Good/Plane=2091,2091,
4:11.5 *** Warning: Create IB Table fail(CE:1 Block:0 Page:0) failed
4:11.5 - Toshiba 19/24nm block pair (0001-0000)
4:11.5 - Good/Plane=2091,2091,
4:11.9 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:11.9 *** Warning: Create IB Table fail(CE:1 Block:1 Page:0) failed
4:11.9 - Good/Plane=2091,2091,
4:12.0 *** Warning: Create IB Table fail(CE:1 Block:1 Page:0) failed
4:12.1 - Toshiba 19/24nm block pair (0002-0003)
4:12.1 - Good/Plane=2090,2090,
4:12.4 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:12.4 *** Warning: Create IB Table fail(CE:1 Block:2 Page:0) failed
4:12.4 - Good/Plane=2090,2090,
4:12.6 *** Warning: Create IB Table fail(CE:1 Block:2 Page:0) failed
4:12.6 - Toshiba 19/24nm block pair (0003-0002)
4:12.6 - Good/Plane=2090,2090,
4:13.0 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:13.0 *** Warning: Create IB Table fail(CE:1 Block:3 Page:0) failed
4:13.0 - Good/Plane=2090,2090,
4:13.2 *** Warning: Create IB Table fail(CE:1 Block:3 Page:0) failed
4:13.2 - Toshiba 19/24nm block pair (0004-0005)
4:13.2 - Good/Plane=2089,2089,
4:13.5 *** IB check fail S:0/0(Data:FFFFFFFF/Spare:0000) ***
4:13.5 *** Warning: Create IB Table fail(CE:1 Block:4 Page:0) failed
4:13.6 - Good/Plane=2089,2089,
4:13.7 *** Warning: Create IB Table fail(CE:1 Block:4 Page:0) failed
4:13.7 ### Err: IB-Table create failed (CE=1,DIE=0).
4:13.7 ### F0-Err:0078 ###
4:13.7 [RESULT] ErrorCode : 0078
4:13.7 + Static Summary: B=0 ,P=0 ,S=0 ,Others=0 ,D1B=0 ,D1P=0 ,D1S=0 ,D1Others=0 ,
00----
[ 2015-09-06 05:39:13 ]
[ UPTool takes 00:04:13 ]
Description: [D:]USB Mass Storage Device(Kingston DT microDuo)
Device Type:??Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0951 PID = 16A1
Serial Number: 001A4D5E8634BE5169922466
Device Vendor: Kingston
Device Name: DT microDuo
Device Revision: 0100
Manufacturer: Kingston
Product Model: DT microDuo
Product Revision: PMAP
Chip Vendor: Phison
Chip Part-Number: PS2251-68(PS2268) - F/W 01.02.53 [2014-03-05]
Flash ID Code: 98DE9892 - Toshiba [TLC]
after error
Description: [D:]USB Mass Storage Device(2268 PRAM)
Current Speed: Full Speed
Max Current: 50mA
USB Device ID: VID = 13FE PID = 3E00
Device Name: 2268 PRAM
Device Revision: 0110
Product Model: 2268 PRAM
Product Revision: 1.00
Chip Vendor: Phison
Chip Part-Number: PS2251-68(PS2268) - F/W 01.00.10 [2013-02-04]
i have this usb
OS Version: Win 7
PC Name : []
DUT Slot: 0
Driver : D
IC Type : 1E-0
ISP Type: 1
F-Slot : 1
4:07.6 1056,1057,
00----
Max Current: 200mA
Chip Vendor: Phison
after error
Max Current: 50mA
Chip Vendor: Phison
